Old 09-05-2004, 02:29 PM
dogood dogood is offline
1990 CRX Overheating
My temperature gauge shows I'm nearly in the red zone. New radiator, new head gasket, new temp sensor, new thermostat and it still shows overheating. Sometimes it falls into the normal zone but mainly inches toward red zone. What else is left to check?
Old 09-05-2004, 02:42 PM
91civicguy's Avatar
91civicguy 91civicguy is offline
Send a message via MSN to 91civicguy Send a message via Yahoo to 91civicguy
Re: 1990 CRX Overheating
most likley its your cluster that's messed up. where is the temp sensor on the 4th gens i need to change mine i think
Old 09-05-2004, 06:22 PM
antmang antmang is offline
Did you replace the fan switch above the oil filter? Does your fan kick on when it's in the red? Turn on your AC the fan should kick on instantly. That will let you know if the fan is working.
Old 09-05-2004, 07:00 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
would say water pump but your car be smoking up like a storm and also wouldnt be going very far...i just get a diff cluster see what happens same thing gott lead to the fan like antmang said
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 09-05-2004, 07:21 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
may have air trapped in the system.
Old 09-05-2004, 07:32 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
when you had the head gasket replaced, did you check to see if the head was warped or cracked? Might wanna check that out man.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 09-05-2004, 07:41 PM
Forunn Daberator
if he had a warped head, chances are he would be smoking like hell.
Old 09-05-2004, 10:58 PM
Hybrid1990crx's Avatar
Re: Re: 1990 CRX Overheating
Old 09-05-2004, 11:00 PM
Forunn Daberator
care to explain that responce?
Old 09-06-2004, 11:43 AM
I was agreeing with you.
Old 09-06-2004, 11:52 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Well did you put coolant in? Some do forget you know?
If the head is warped i'm pretty sure he would see some leaking.
Old 09-06-2004, 06:34 PM
Did you buy a quality thermostat? Or just some $7 one. They are getting shittier and shittier.
ZC stuff
