lumina starting
96 lumina just had intake mainfold gasket put on now after 500 miles i try to start it and it seems to but immediately stalls when i let go of the key. When it stalls it sounds like a clanking sound as it comes to a stop. If i give it the gas it runs but I smell gas and don't want to make matters worse?????
Re: lumina starting
Crankshaft Position Sensor? Anyone have any other ideas?
Re: Re: lumina starting
Re: lumina starting
That vacuum hose would definately do that, not the sound, though. It was probably a backfire that popped the hose off. It may do it again, then you may need to find the cause of that. Or not. Glad it's OK now. Good job! It's amazing what just taking a critical look and fiddling a little bit can fix sometimes.
Re: lumina starting
If the vacuum booster was disconnected that would really cause a problem. By the way you were describing it, I might have suspected the security system to have been causing you trouble.
