Old 09-05-2004, 10:26 AM
adaly86 adaly86 is offline
front bumper removal
When removing the front bumper from a 91 civic, do i just have to remove the side screws at the front of each wheel archj (2 each side), the screws behind the lights in the bumper, and the 2 screws under the car?
Thanks, Alan
Old 09-05-2004, 12:40 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: front bumper removal
Yup, you've gotta lift it a bit, pull the sides out a bit and it should come right off. GL
Old 09-05-2004, 02:25 PM
ok thanks, when looking at the bolts behind the lights, what would be the best way to undo them, its kind of a tight space
Old 09-05-2004, 02:58 PM
johnb16a2's Avatar
Just need an socket exenstion or two and you'll reach them with no problem.
BTW, the reason you have to lift up the bumper a bit and pull at the same time is there are hooks that help hold the bumper on until you can get the bolts in and tight. GL
