RPO Codes
Looking for a web site that has a complete list of all RPO codes for the fourth gen camaros... I really want to know what RPO code WT4 is.
Re: RPO Codes
Go to www.camarosource.ca, they have a complete listing by year from 67 to 02.
1994 Camaro V6 A4 - RIP 3/1/06 ![]() http://www.cardomain.com/memberpage/805164 1994 Camaro Z28 A4 - Bought 4/6/06 |
Re: RPO Codes
I am looking at a 1997 SPECIFIC list of RPO's and do not see WT4 on it. it goes: WS6, WU6, WU8...
It does have Z4C as the 30th Anny appearance Package (white w/orange) RPO Description ABN Sensor, Oxygen, Non-heated AG1 Adjuster, 6-way Power, Driver Seat AG4 Adjuster, 2-way Manual, Driver Seat AH3 Adjuster, 4-way Manual, Driver Seat AK5 Restraint System Front Seat, Inflatable, Driver and Passenger AN4 Restraint Provisions, Child AQ9 Seat, Passenger and Driver, Recline AU0 Lock Control, Remote Entry AU3 Lock, Side Door, Electric A31 Window, Power Operated, Side A90 Lock, Rear Compartment Lid, Remote Control, Electric B35 Floor Mats, Rear, Carpeted Insert B84 Exterior Molding, Body Side CC1 Roof Hatch, Removeable Glass Panels C41 HVAC System, Heater C49 Defogger, Rear Window Electric C60 HVAC System, Air Conditioner, Manual Control DD9 Mirror, Outside, LH and RH, Remote Control, Electric, Breakaway, Painted DE4 Sunshade, Removable Hatch Roof DG7 Mirror, Outside LH & RH, Remote Control, Electric, Painted DL5 Decal, Roadside Service Information D35 Mirror, Ouside LH Remote, RH Manual, Painted D82 Paint Special FE2 Suspension System, Ride Handling FE9 Certified Emmison, Federal F41 Suspension System, Firm Ride Handling, Front and Rear GU2 Axle, Rear 2.73 Ratio GU4 Axle, Rear 3.08 Ratio GU5 Axle, Rear 3.23 Ratio GU6 Axle, Rear 3.42 Ratio G80 Axle, Rear Positraction (Limited Slip) ILD Trim Interior Design IL2 Trim Interior Design IPB Trim Interior Design IPC Trim Interior Design IP2 Trim Interior Design IP3 Trim Interior Design J41 Brake System, Power, Front Disc, Rear Drum, Cast Iron J65 Brake System, Power, Front Disc, Rear Disc KG9 Generator, 140 Amp K05 Heater, Engine Block K34 Cruise Control, Automatic Electronic K68 Generator, 105 Amp LT1 Engine, 5.7L (V8) SFI L36 Engine, 3.8L (V6) SFI MM5 Transmission, 5-Speed Manual (Merchandising Option) MM6 Transmission, Manual, 6-Speed, Borg-Warner, 85mm, 2.66 1st, 0.50 6th, O/D MN6 Transmission, 6-Speed Manual (Merchandising Option) MX0 Transmission, Automatic O/D (Merchandising Option) M28 Transmission, Manual, 6-Speed, Borg-Warner, 85mm, 3.36 1st, 1.35 3rd M30 Transmission, Automatic, 4-Speed, 4L60-E, Electronic M49 Transmission, Manual, 5-Speed, Borg-Warner, 77mm, 3.75 1st, 0.76 5th, O/D Emission NB6 Emission System, California Requirement, Tier 1 NF2 Emission System, Federal Requirements, Tier 1 NK3 Steering Wheel, Sport, Soft Rim, Simulated Leather NP5 Steering Wheel, Leather Wrapped NW9 ASR-Traction Control N36 Steering Wheel, 4 Spokes, Sport N60 Wheel, Aluminum, Painted N92 Cover, Wheel, Bolt-on N96 Wheel, 16 x 8, Cast Aluminum N98 Wheel, Chrome, Var 2 PE0 Wheel, 16 x 8, Aluminum, Light Weight, Styled P05 Wheel, Chrome, Var 1 QB3 Wheel, 16 x 7.5, Steel QCB Tire, P235/55R16 BW R/PE ST TL AL2 96T QEA Tire, P215/60R16 BW R/PE ST TL AL2 94T QFZ Tire, P245/50ZR16 BW R/PE ST TL AL3 QII Tire, P215/60R16 BW R/PE ST TL AL3 94H QLC Tire, P245/50ZR16/N BL R/PE ST TL HW4 STE Plant Code-St. Therese, PQ, GM of Canada T39 Lamp Turn Signal, Auxiliary T43 Spoiler, Rear T82 Headlight Control, Automatic On, Off T96 Lamp, Fog UA6 Theft Deterrent System UB3 Instrument Cluster, Oil, Coolant, Temperature, Volts, Trip Odometer, Tachometer UK2 Lever, Directional Signal, Multifunction UK3 Electronic System Accessory Control UL0 Radio, AM/FM Stereo, Seek/Scan, Auto Reverse Multi Search, Auto Tone, Clock, ETR UM6 Radio, AM/FM Stereo, Seek/Scan, Auto Reverse Cassette, Clock, ETR UN0 Radio, AM/FM Stereo, Seek/Scan, Compact Disc, Auto Tone, Clock, ETR UQ0 Speaker System 4, Dual Front Door Mounted, Standard Range Quarter/Shelf UZ7 Speaker System 8, Quad Frt Dr Mtd, Dual Sail Pnl, Dual Rr Hatch, Amplifier U1S Player, Multiple Compact Disc U19 Speedometer Instrument Kilometers and Miles, Kilometer Odometer U62 Speaker System 4, Dual Coax Front, Dual Coaxial Package Shelf U73 Antenna, Fixed. U75 Antenna, Power VG8 Label, Vehicle, Notice to Buyer VK3 License Plate, Front Mounting Package WS6 Performance Package, Formula/Trans Am WU6 Sales Package, Fikehawk, Upfitter WU8 Sales Package, Z28 SS, Upfitter W51 Entertainment System, Radio, AM/FM Stereo, Seek/Scan, Cassette, 4 Speaker System, Standard Range W52 Entertainment System, Radio, AM/FM Stereo, Cassette, Equalizer, 4 Speaker System, Coaxial W53 Entertainment System, Radio, AM/FM Stereo, Compact Disc, Equalizer, 4 Speaker System, Coaxial W54 Entertainment System, Radio, AM/FM Stereo, Cassette, Equalizer, 10 Speaker System, Amplifier W55 Entertainment System, Radio, AM/FM Stereo, Compact Disc, Equalizer, 10 Speaker System, Amplifier W57 Entertainment System, Radio, AM/FM Stereo, Cassette, Equalizer, 4 Speaker System, Coaxial W58 Entertainment System, Radio, AM/FM Stereo, Compact Disc, Equalizer, 4 Speaker System, Coaxial W59 Entertainment System, Radio, AM/FM Stereo, Cassette, Equalizer, 6 Speaker System, Dual Front Front Door Tweaters/Woofers, Extended Range Shelf W66 Merchandised Package, Formula W73 Entertainment System, Radio, AM/FM Stereo, Compact Disc, Equalizer, 6 Speaker System, Dual Front Front Door Tweaters/Woofers, Extended Range Shelf Y3F Sales Package, RS Camaro, Upfitter Y81 Merchandised Package, Firebird Y82 Merchandised Package, Trans Am, Base Coupe Y84 Merchandised Package, Trans Am Y87 Merchandised Package, Performance Enhancement Z28 Merchandised Package, Special Performance Z4C Appearance Package, 30th Anniversary 01U Primary Color Exterior, Special 05Q Molding Color, Cyclamen 05U Primary Color Exterior, Cyclamen 1LE Performance Package Components 10C Trim Combination Cloth, Artic White 10I Interior Trim, Artic White 10T Top Color, Artic White 10Q Molding Color, Artic White 10U Primary Color, Exterior, Artic White 102 Trim Combination, Leather, Artic White 103 Trim Combination, Leather, Artic White 13Q Molding Color, Bright Silver Metallic 13U Primary Color Exterior, Bright Silver Metallic 14B Trim Combination, Cloth, Lt. Gray 14D Trim Combination, Cloth, Very Dark Gray 14I Interior Trim, Lt. Gray 31Q Molding Color, Bright Green 37U Primary Color Exterior, Dark Birght Teal Metallic 41Q Molding Color, Black 41T Top Color, Black 41U Primary Color, Exterior, Black 48Q Molding Color, Dark Yellow Green Metallic 48U Primary Color, Exterior, Dark Yellow Green Metallic 52B Trim Combination, Cloth, Lt. Neutral 52D Trim Combination, Cloth, Lt. Neutral 52I Interior Trim, Lt. Neutral 522 Trim Combination, Leather, Lt. Neutral 56T Top Color, Med. Neutral II 73B Trim Combination Cloth, Flame Red 73I Interior Trim, Flame Red 79Q Molding Color, Mystic Teal Pearl 79U Primary Color Exterior, Mystic Teal Pearl 80Q Molding Color, Medium Quasar Blue Metallic 80U Primary Color Exterior, Medium Quasar Blue Metallic 8X1 Vehicle Label, Fasten Seat Belt 81Q Molding Color, Bright Red 81U Primary Color Exterior, Bright Red 88Q Molding Color, Bright Purple Metallic 88U Primary Color Exterior, Bright Purple 92B Trim Combination Cloth, Medium Dark Pewter 92I Interior Trim, Pewter 96Q Molding Color, Cayeene Red 96U Primary Color Exterior, Cayenne Red, Metallic
1995 Camaro Z28, 383ci 485+hp 495ft-lbs SOLD!!!
1965 Ford F100 1967 Chevrolet Impala (Sold) 1972 Chevrolet Chevelle (Sold) 1972 BMW R60/5 (Sold) 1980 Harley Davidson FLH 1987 Harley Davidson XLH 1992 Astro EXT AWD 1992 Chevrolet Cavalier 2000 Monte Carlo SS Pace Car 1087/3222 (Sold) 2001 Pontiac Sunfire 2002 Trailblazer LTZ (Sold) South Carolina F and Y Bodies www.SCFYB.com |
