Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 09-04-2004, 05:24 PM
Jocelynalissa Jocelynalissa is offline
Can't Start Vehicle...Possibly Alarm Problem
HI!
Is there anywhere to locate the owners manual online (PDF)?
I can't turn the key on my durango but there is full power inside ...CD player, hazards....also the steering wheel is not locked, and the vehicle is locked in park. I can't even get to accesories to put up the windows which are all down....
The alarm went off just before this all happened, but I turned it off. Any ideas anyone? please help....
1999 dodge durango
Old 09-04-2004, 07:43 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Can't Start Vehicle...Possibly Alarm Problem
Have you tried wiggling the column around along with the key? Do you mean that you can not turn the key? If so, that's not an alarm problem. Also, is this factory alarm?
Old 09-06-2004, 03:33 PM
durango wont start.....
Factory alarm. Cannot turn key at all. Tried wiggling steering column. Cannot move from park on the steering column drive tree. Thanks for the help
Old 09-06-2004, 07:13 PM
It isn't an alarm issue then. Sounds like your wheel has locked to where their is a lot of pressure on the locking pin inside the column. Or, maybe the cyl. lock is bad? There is no alarm out there that prevents you from turning the key.
Old 12-15-2004, 08:05 PM
micash21 micash21 is offline
I had the same issue when my alarm went off. Some times with the factory alarm it will "arm" itself and u wont know its goin off. I had to disconnect the battery overnight and then reconnect it. Then i rearmed the alarm and disarmed it.
Old 12-15-2004, 09:46 PM
jonheu jonheu is offline
Re: Re: Can't Start Vehicle...Possibly Alarm Problem
I had a problem like that before. Try stepping on the brake while wiggling and turn the key and see if that works.
Old 04-03-2005, 08:07 AM
RacinMyDurango RacinMyDurango is offline
Same thing but no alarm involved?
Hi Gang my 2001 D has done the same thing as posted here. I pulled in to my driveway shut it off, came out 2 hours later to leave and the key while in the ign will not move AT ALL! only diff is my alarm did not go off? HELP!
kb
