Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 09-04-2004, 03:49 PM
Autobanaurora's Avatar
Autobanaurora Autobanaurora is offline
Fuel gauge gone buzzerk
98 Autobahn Aurora fuel gauge, 90,000 miles goes crazy when filled up. Just noticed when tank is past the F mark, the gauge goes up and down from F to E then back to full every 30 seconds or so. Seems when the gauge begins to move off full, it stops. The range stays the same until the gauge touches E then it goes blank then resets. Any suggestions?
Old 09-04-2004, 06:01 PM
Isnibs's Avatar
Isnibs Isnibs is offline
Try
'http://www.automotiveforums.com/vbulletin/showthread.php?t=226093&highlight=Fuel+gauge'
remove leading and following '
1996 Aurora Black / grey
Old 09-04-2004, 07:31 PM
thanks
Seems I'm not the only one, thanks, after I restarted the car and drove for 40 miles it quit. Don't think I want to replace the sending unit but thanks again. One of those days I guess...
Old 09-28-2004, 09:14 PM
GuMan GuMan is offline
I had the same thing happen to me.
Come to find that the float arm was
chaffing the sender wire, and it started
to short out to the pump GND wire in the
tank!
Luckily, the sender is low voltage. Anyway,
this finally caused the pump to fail.
The pump and sender are easy to get to.
Pull the liner in the trunk and there is a door
on the trunk floor the top of the tank and
the pump/sender unit.
GuMan
Old 10-03-2004, 07:21 AM
Re: Fuel gauge gone buzzerk
Thanks, I'm going to check that, funny, it hasn't been doing it lately. I'll check the wire.
Old 11-22-2005, 08:31 AM
mcnu's Avatar
mcnu mcnu is offline
i took the trunk apart last night and took the cover for the fuel pump off. however, i really didnt see what was supposed to be done once it was removed. I have the problem of the gas gage not working all the time and going nutz. any help would be helpful. thx
