Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 09-04-2004, 12:20 PM
B13Turbo93's Avatar
B13Turbo93 B13Turbo93 is offline
H-e-l-p
my 93 sentra E is being such a pain in the ass! after doing many system checks I still cant figure why my car is bogging? Fuel pump voltage is correct (I think its getting to much fuel),I know its throwing a coolant temp and MAF sensor, and the dist. and coil pack are working fine putting out what I can see and have tested to be very good spark. when cold the car will run great but after a few moments when the accelerater is pressed the car bogs heavily sounding as if its the intake sucking in to much air, after that there is a very distinct gas odor coming from the car. any ifo is greatly appreciated-THANKS!
Old 09-05-2004, 02:05 AM
shi shi bog shi shi bog is offline
Banned
Re: H-e-l-p
im not a car expert but your fuel mixture might be rich
well thats what i think
Old 11-23-2004, 09:29 PM
bluelichen2003 bluelichen2003 is offline
Re: H-e-l-p
The strong fuel smell is the first indication. To me it would seem that you are getting too much fuel. You may want to check the fuel pressure regulator or have the injectors tested. Something else you can check is the mass-airflow sensor, when this doesn't tell the computer the right amount of air is flowing the computer will compinsate with the fuel to get the proper fuel ratio.
Old 11-24-2004, 01:46 PM
200SXGTi-R 200SXGTi-R is offline
Re: H-e-l-p
is you car turbo? if so check all you hoses and intercooler piping sound like boost is leaking from somewhere. do you see black smoke?
Old 11-29-2004, 03:54 PM
In2Deep In2Deep is offline
problems
does it smell like straight gas or kinda a burning egg smell? if its just a strong gas smell, it might be the fuel return line leaking, which causes pressure loss. if its the burning egg smell, check your catalytic converter, it might be clogged. also, when was the last time you got a new o2 sensor? check that too. hope this helps.
1991 Ford Explorer 4d, 4wd, 5sp
1994 Nissan Sentra XE w/JDM sr20 swap - sold
Old 11-29-2004, 06:02 PM
destiniespunk destiniespunk is offline
Send a message via ICQ to destiniespunk Send a message via AIM to destiniespunk
Re: H-e-l-p
might be distributor, thats what the guy at the garage told me is probably wrong with mine
Old 01-06-2005, 09:55 AM
B13Turbo93's Avatar
Ah Ha
found out that my fuel tank is rusting and the the crud and rust was clogging my fuel delivery at the pump screen. now I am in search of a new tank preforably plastic? Thanks for the info though!
