Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 09-04-2004, 10:31 AM
Car Man Car Man is offline
Question Will Not Start When Cold
I have a 1996 Bravada that will not start when cold. If I pour a little gas in the intake it will start right up. Once it has warmed up it will start right back up. Any help would be great.
Thanks
Old 09-06-2004, 10:14 AM
BigDaddy Royster's Avatar
BigDaddy Royster BigDaddy Royster is offline
Re: Will Not Start When Cold
Does this model have fuel injectors? If so, sounds like one or two of them may be clog. You should try some fuel injector cleaner. Afterwards I would also look at all of the plugs and make sure they are clean and gap right according to the manufactures requirements. Hope this helps!!!!!
95 Olds Aurora (Northstar 4.0L w/Autobahn Package @ 250+ HP)
98 Olds Bravada (4.3 Vortec)
95 BMW 740 i (salvage purchased from insurance co. to be fixed up)
Check out other pictures of my RoRa at WWW.CarDomain.COM
BigDaddy Royster
Old 09-07-2004, 07:41 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
There should be some trouble codes or at least some pending codes. See if your local parts house will give you a free OBDII scan and check for pending codes if the check engine light is not on.
Old 10-15-2004, 07:44 PM
tcpip95 tcpip95 is offline
Have your fuel pressure regulator checked. I had similar problems, and that was the problem
