Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 02-08-2002, 05:46 PM
ky_infiniti2000's Avatar
ky_infiniti2000 ky_infiniti2000 is offline
Send a message via ICQ to ky_infiniti2000 Send a message via AIM to ky_infiniti2000
Series Vs. Stereo
I have 2 4-ohms subs. When wired in Series the effecitve load is 8-ohms. My amp is rated at 1x 300W @ 4-ohms or 2 x 150W @ 2-ohms.
When wired in series, the effecitve wattage is 150W total(or 75W per sub)
When wired in stereo, the effective wattage is 75W per speaker as well.
So what are advantages/disadvantage of running in series vs. stereo?
Old 02-08-2002, 07:14 PM
frogg's Avatar
frogg frogg is offline
Send a message via AIM to frogg
I've never heard of "wired in stereo" before; I've only heard of wired in series and wired in parallel..
What kind of sub do you have? brand/model?
Is it a mono amp or stereo?
If you are taking a stereo amp and making it mono you would be bridging it.
Troy P.
My "pretty-much-stock" G20
:apoke:
Old 02-09-2002, 12:40 AM
Yes...I mean running the amp in stereo or mono.
i have 2 Eclipse 86100.4 (10" 4ohm, Continuous Power Handling: 175W
Music Power Handling: 350W).
Pushing them i have a 150.2 Orion Colbalt amp.
Old 02-09-2002, 08:42 AM
NismoPC's Avatar
NismoPC NismoPC is offline
Re: Series Vs. Stereo
Since MONO combines the stereo signals into one path, the overall bass response (frequency) acheived would be greater than running the amp in stereo sending seperate bass frequencies to each speaker.
The only issue I see is when you run the two in series, the ohms is 8 which will lower the output wattage of the amp and therefore lessen the amps effectiveness. On the other hand, the amp will run cooler at 8 ohms instead of 4 or 2. But....
....ultimately, for a amp that runs 4 ohms in MONO, you should have went with two 8 ohm subs and ran them in parallel or two 2 ohm subs and run them in series. that would have achieved the 4 ohm load. Or any combination of subs that net you a 4 ohm load.
Brandon
'96 G20 - modified
Corvette ZR1 vs Mercedes SL65 Black Series vs Lamborghini LP640 vs Dodge Viper SRT10 trev0006 Car Videos 0 01-23-2009 05:50 PM
97 gt stereo vs stereo with sterring controls Blueflameguy2 Grand AM 4 05-22-2008 08:23 PM
Diesel 5 series vs Gas 5 series trev0006 Car Videos 0 11-30-2007 07:28 PM
B series vs H series GWInquisitor14 Forced Induction 6 03-27-2004 02:16 PM
7-series vs S-Class vs A8 crayzayjay Car Comparisons 86 04-17-2003 01:04 AM
