Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 09-04-2004, 09:50 AM
olaf_fiero27 olaf_fiero27 is offline
86 Fiero Taillight Problem
Hi,
I have an 86 Fiero GT and when I turn the headlights on the stationary lights in the back turn on like they are supposed to but when the brake is depressed they do not get brighter, I am thinking that it's a ground but im not 100% sure so could you guys please help me out?
Thanks a lot
Old 09-04-2004, 11:31 AM
GTpaul86 GTpaul86 is offline
Send a message via AIM to GTpaul86
Re: 86 Fiero Taillight Problem
does the thrid brake lights come on
Old 09-04-2004, 05:59 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Check the switch on the brake pedal, if the taillights work that's usually where the problem lies. It CAN'T be a ground because the tail lamps and brake lights share a ground wire. If the ground is bad neither work.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 09-04-2004, 08:40 PM
Thanks man but i Found the problem there was no Fuse in the fuse spot and now they work just the guy I bought i from removed it
Thanks
Old 09-04-2004, 08:45 PM
Good news, but be careful. That fuse could have been pulled because it kept blowing, and that could mean a short somewhere.
Wanted to buy:
Old 09-04-2004, 10:03 PM
Ok thanks man ill let you know if anything happens
Old 09-04-2004, 10:06 PM
Hey I have another question.
(I have a 4 speed)
When I shift into reverse the reverse lights come on but when i let go of the shifter it slips but is still in reverse but the lights only light up when it is held in place
Old 09-04-2004, 11:49 PM
FierceGT's Avatar
FierceGT FierceGT is offline
Send a message via MSN to FierceGT
Under the center console, there is a white switch that is depressed to activate the backing lights when the shift lever is in the reverse position. You probably just need to adjust the position of the switch.
Old 09-05-2004, 09:46 AM
Ok and how about the Pontiac on the taillights why doesnt that work?
Old 09-05-2004, 09:55 AM
The "Pontiac" letting on my 86 2m4 doesn't light up, it's just depressed lettering in the bumper cover. I didn't know the GT's had lighted letters. If I had to guess I'd say bulbs or a bad wire.
Wanted to buy:
Old 09-05-2004, 12:33 PM
Ok can someone give me some detailed instructions on how to fix my reverse light problem when you shift into reverse the back up lights come on but when you let go of the shifter it slips out ( its still in reverse ) but the back up lights don't come on
Thanks
Old 09-06-2004, 08:49 AM
IF it is a GT then the pontiac on the back does light up there is 4 bulbs 2 for each taillight and it should come on when you turn the key on i am about to hook mine into a switch because i like to do a lil street racing and its kinda hard to hide from the cops when you have this big PONTIAC lit up on the back of your car
Old 09-06-2004, 09:15 AM
It depends on where your backup light switch is located. Some are on the shifter while others are on the tranny. If it's on the shifter, you need to pull out both ashtrays, remove the 4 (2 per side) 7mm screws beaneath them, unscrew the shift knob and remove the console. there are 3 7mm screws holding on the power window switch plate (just a blackout plate if you have crank windows) and under this plate you'll find a small switch mounted to the right. It's adjustable - by moving the 2 nuts on the shaft you can move the plunger closer or farther away from the shift lever. In your case you want it closer. Reassemble and drive happy.
** I'm assuming the 4 speeds are the same as the getrag 5 speeds rather then the izuzu 5 speeds - Should there be no switch under the console then it's on the tranny (similar to the izuzu) you'll need to locate it and replace it - they can't be adjusted.
*** The entire problem CAN be caused by sloppy shift cables. If the shifter flops around and feels loose and gears are hard to find, you may need to tighten the cables.
Wanted to buy:
