Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 09-04-2004, 02:59 AM
willie3x willie3x is offline
95 Jetta Idle problem
Someone please help me, about a month ago my jetta started idling eraticaly, and stalling when I stop and going down hill(my foot off the gas)
Ive checked the vaccum lines, replace the spark plugs, air filter and the cadlitic converter.
Its also smoking when I start it up in the mornings (white smoke) and hard to keep started any ideas?
email me directly at [email protected]
and thanks in advanced
Old 09-07-2004, 07:01 PM
gmcgough gmcgough is offline
Re: 95 Jetta Idle problem
Start by checking the obvious.........make sure all 4 cylinders are firing. If one of the cylinders is missing alot or not firing then you can tell by systematically removing the spark plug wires from the distributor. Disconnecting the spark plug wire on a good cylinder will cause the idle to change dramatically. If you disconnect one of the wires and have little or no change in idle then you have isolated your problem. Then you have to figure out if it is a clogged injector or perhaps its not getting a spark. Hope this helps.
Old 09-08-2004, 07:13 PM
boschmann boschmann is offline
Is it white smoke or steam?
Old 09-08-2004, 07:54 PM
nicoleos nicoleos is offline
Did you check the idle control motor? I had a cadillac with that problem.
