Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 09-04-2004, 01:32 AM
ZCrazyman ZCrazyman is offline
Something is Arigh.....
Ok i just got this Z31 and its a great car and the AC blows really cold and really hard...................UNTIL u reach a hill and have to step on the gas harder...................IT TURNS INTO THE HEATER ON FULL BLAST and the display still says "AC" and the temp is at 60f and guess what its hot outside and the heater is not what i want to feel when i turned on the ac now the ac runs cold for hours on flat ground when the car is not accelerating... but as soon as u step on it it turns HOT... it is a non turbo 85 with all the options... any suggestions???
4th gen Civic... is there a better car to own??
My Ebay Items for sale: and more to come... CHECK THEM OUT!!!
http://cgi6.ebay.com/ebaymotors/ws/e...sort=3&rows=50
Old 09-04-2004, 02:05 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
There is only a few Z31 owners on this forum so www.z31.com might have more info on your problem. Might just be that the AC has a cut off switch built into it that kills the air for whatever reason. Engine getting too hot, etc and so on...
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 09-04-2004, 02:09 AM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: Something is Arigh.....
after you get done stepping on the gas, does it start blowing cold air again?
ZedEx Crew Member #2
Old 09-04-2004, 07:25 AM
yes it blow's ice cubes after your done on the gas
Old 09-04-2004, 11:26 AM
i am guessing there is something wrong with your ac compressor. check all your belts, they should be able to turn 90 degrees, no more or no less.
Old 09-04-2004, 08:41 PM
ok the compressor works perfect u can HEAR the vents "change" when u step on the gas i went looking for leaks today but found none maybe the leak is under the dash
Old 09-05-2004, 12:12 AM
longlivetheZ's Avatar
longlivetheZ longlivetheZ is offline
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
Brent to the rescue!... J/k....it's a vaccume leak! My car does the same thing except my car's A/C doesn't work...instead of blowing cold when you're off the gas then getting hot, mine just blows hot when I'm off the gas then gets HOTTER when I'm on it...it must get ~100 degrees when I'm on the throttle...it's nearly painful. I asked a question about this same exact thing 4 or 5 days ago...read up.
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Old 09-06-2004, 01:04 AM
sounds good but all my vac lines look good what i looked for more vac leaks but i couldnt find any all the lines look good
Old 09-06-2004, 10:44 AM
all the lines LOOK good. a small hole that you couldn't see still could mess up the line. i hope you find out what is wrong.
Old 09-06-2004, 12:25 PM
Antiburn's Avatar
Antiburn Antiburn is offline
Send a message via AIM to Antiburn
If you wana just correct the problem just buy all new vac lines. Why wouldnt you want to replace those 19 year old pieces of rubber anyway. I did when I got my 85 and I havent had vaccume poblems since. Except that rough idle which I cant figure out what it is. Maybe its the gas spraying out of the gas pressure sensor hoses spraying all over the timming belt. Were see in this next week if thats fixed it.
Old 09-06-2004, 02:27 PM
E Honda's Avatar
E Honda E Honda is offline
Send a message via Yahoo to E Honda
To track a vac leak you can get some wd40 and spray around the vac lines........Listen for the idle speed to change.......If it does that means the vac is sucking in the vapors from the wd40....
Good Luck
Old 09-06-2004, 02:32 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Hey that's a good-one!
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 09-06-2004, 08:55 PM
you don't remember me saying that 1via? i suggested that a few months ago, except with carb cleaner instead of wd40. i did it on my car and no idle changes, so supposedly i have no vacuum leaks!!
