Old 02-08-2002, 05:02 PM
civic7771 civic7771 is offline
b20b+b16a head durable?
hi i am new here..i know there might be someone post this question before but i would really wanna know in detail is this kind of engine modification is durable?Some of my frens said this combination will have problems a short period of time(3 months).I have tested this monster and i admit it is really fast and it evens beats my ex-4g63t engine swap to a mirage.I currently driving a EK3 with d15b engine and i plan to swap.I need something that powerful and durable!
my choice:
-CRV block with b16a head--powerful but durable???
-b18c R<<--this is very expensive in my country!
pls help thanks.
p/s=my friendd's b20b+b16a head are using 85mm piston not 84.5mm.any different???
Old 02-08-2002, 07:37 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Well any kind of hybrid engine is going to have a problems, its jsut the way it is. YOu have to remember that your making up a combination that was never ment to be. For the B16a head to work properly on the B20 block it needs to have the combustion chamber machined out, which of course weakens it a little. And the B20 bottom end and block needs to with stand revs quite far above what it was designed for to make the most of the VTEC.
Then you also have to make sure you have the right injectors so it dosnt lean out, and get the cam and ingnition timeing right.
Its not a simple build the engine, stick it in the car and you have a dialy driver. Its a good project for someone with the time and skills and patiance to keep it maintianed, but if your looking for a simpler bolt in swap then I recomend a B18c from a GSR/VTiR/SiR-G Integra, or a B16a from an SiR Civic.
Where in the world are you?
Old 02-08-2002, 10:53 PM
hybridDC2 hybridDC2 is offline
guess what i saw today, a F20c head mated to a 2002 2.4L CRV block.
anyway, isnt the bore on the b20 the same as the b18; 81mm?
Old 02-09-2002, 01:42 AM
Phatwhippin_CRX Phatwhippin_CRX is offline
Send a message via ICQ to Phatwhippin_CRX Send a message via AIM to Phatwhippin_CRX Send a message via Yahoo to Phatwhippin_CRX
CR-VTEC kicks ass....
go here to learn all about it:
www.crvtec.com
1989 DOHC VTEC CRX Si
C'mon, it's only a Honduh...can't be fast!
I AM the Anti-Rice!
Swap info, Turbo tech, and naked chicks!
Old 02-09-2002, 05:12 AM
i'm from Malaysia..the ppl playing vtec here are totally crazyy.There is one ek9 modified to 2400 cc..darn fast.I know crvtec is fast i just doubt bout its durability.So u guys mean if i tuned it and maintain it well i wont have much problems with those conversion?
Old 02-09-2002, 11:32 AM
Well..... the reliabiltiy depends on how well built the setup is. And the better you build it, the more $$$$ it's gonna cost ya....
I AM the Anti-Rice!
Old 02-09-2002, 03:08 PM
Moppie's Avatar
Master Connector
You either need lots of money to pay the people with the right mechanical skills and know how to make it work properly, or you need to have the mechanical skills and know how yourself. Since you had to ask about it here it sounds like you need the former, Lots of money.
IMO its simply not worth it, you could get a similar level of performance from a modified B18c.
Old 02-10-2002, 11:36 PM
not true...... properly built (albeit more $$$ possibly) a CRVTEC stomps a GSR motor...... hands down.
I AM the Anti-Rice!
Old 02-11-2002, 02:37 AM
Moppie's Avatar
Master Connector
Yes pump $30,000 into both a B18c and a CRVTEC its quite possible the CRVTEC might make more hp and have a faltter torque curve.
But I think if your doing in on a budget (like most of us are ) then the B18c will provide all the performance you need with out the reliablity issues.
Remember that to get the B18c killing levels of power from a B20/VTEC hybrid you have to be able to rev it to the same high RPM levels as the B18c, which is something the B20 bottom end was never designed to do, and so it requires work to get there safely. However the B18c is designed to be high reving, and will do it all day long with little effort.
If you have the money, patiance and technical skill then by all means go build a CRVTEC, but dont be surprised if it dosnt work first time, because it won't.
If your short on budget, time and technical know how, then stick with simple swaps that are well proven, well documented and fairly common. like the B18c, or B16a swap.
B20B Cylinder head on a B81A1?? NANOO JDM Motor & Parts info/chat 8 01-04-2005 08:35 AM
FS: B16a , B16a head, 91 LS motor, and B-series civic dropshop '88 - '91 Civic | CRX | Wagon | Shuttlee 3 11-29-2003 02:28 AM
JDM OBD-1 B16a head for sale, OBD-1 B16a engine harness for sale, GSR intake manifold CRXtc Engineering/ Technical 0 09-09-2003 10:23 AM
What turbo on a B20b/B16 head all stock ? figaro4038 Forced Induction 6 10-25-2002 02:27 PM
