Old 09-03-2004, 07:21 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
1994 Cavalier Check Engine Code Reading
Guys, I can't seem to be getting the check engine lights out of my 1994 Cavalier.
It has the 12 post ALDL connector but the A-B Test jump is not revealing any codes for me.
Can anyone help?
Old 09-03-2004, 07:25 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 1994 Cavalier Check Engine Code Reading
do you have the ignition in the on position with the engine off???
Old 09-03-2004, 07:30 PM
BlazerLT's Avatar
AF -Advisor
sorry, I jump a and B and turn the key to ON just like everyone says and the codes aren't coming.
I have heard mine might be OBDII or GM disabled paperclip code reading on the 1994.
Can anyone help me?
Old 09-03-2004, 07:41 PM
richtazz's Avatar
Gm didn't go to OBDII until 96, check your ECM fuse, it may be burnt.
Old 09-03-2004, 07:44 PM
BlazerLT's Avatar
AF -Advisor
If the ECM fuse was gone, don't you think the engine would not work?
Old 09-03-2004, 07:49 PM
richtazz's Avatar
it would run in limp home mode
Old 09-03-2004, 07:56 PM
BlazerLT's Avatar
AF -Advisor
But it is running amazing.
39+ MPG on the highway etc....
Old 09-03-2004, 08:04 PM
richtazz's Avatar
why are you checking for codes, did your check engine light come on, or are you just curious?
Old 09-03-2004, 08:06 PM
BlazerLT's Avatar
AF -Advisor
Car has been dying on my GF two days ago while coming abck from college and I want to see if there was any codes stored in the computer.
Women don't notice computer codes.
Old 09-03-2004, 08:07 PM
richtazz's Avatar
has it ever died on you, or can you give me what led up to it dying?
Old 09-03-2004, 08:10 PM
BlazerLT's Avatar
AF -Advisor
chekc the other thread on that topic.
Anyone know how to jump codes on a 1994 Cavalier properly, I am following the book and it isn't happening.
Old 09-07-2004, 10:49 AM
richtazz's Avatar
does your check engine light come on when you turn the key on without starting the car? IF not, someone may have removed the bulb.
Old 09-07-2004, 12:08 PM
BlazerLT's Avatar
AF -Advisor
It does.
Thanks for the tip though.
Old 09-07-2004, 12:35 PM
richtazz's Avatar
I was trying to go back to the simplest thing first, since this has been a mind-boggler. Unless there is a broken wire to your ALDL connector, it doesn't make sense that you can't pull the codes. I'm afraid you have me stumped, let us know what you figure out if you do.
Old 09-07-2004, 01:05 PM
BlazerLT's Avatar
AF -Advisor
I heard that GM disabled the PIN jump way to get the codes on a 1994.
People at J-Body.org are stumped also.
