91 camaro dies
my friends got a 91 camaro,it starts up fine,drives fine,but when hes at a red light it seems to stall down & die,when the engine is cold it wont die,but when its warm it will,I've replaced the fuel filter,ive had the fuel pump checked out & its working fine,ive had the coil checked out its fine,we did put on an aftermarket air intake & the factory intake had a iat sensor & its not connected to the air intake,so that may be the problem,but if you have any information on what it could be,it would be helpful
In the process of B00stin my D |
there is the problem, need to get the iat sensor reconnected.
Re: 91 camaro dies
WHERE THE HELL DID YOU GET THE AFTERMARKET INTAKE...lol i have looked everywhere :P i have a 91 camaro as well and i have the same opinion get the sensor reconnected
Re: 91 camaro dies
plug that IAT in and you'll be golden...
*Better power-to-weight ratio than a C6 corvette* |
Re: 91 camaro dies
if not the that sensor, try the oxygen sensor. it might be bad, it does not affect engine operation until the engine is warm (in closed-loop). Someimtes the check engine light will not turn on even if it is bad.
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
Re: 91 camaro dies
check engine won't come on if the injectors are bad either.
Re: 91 camaro dies
check the o2 sensor
Re: 91 camaro dies
if it ran ok before you put the new intake on then theres your problem. plug in that IAT.
