Old 09-03-2004, 02:35 PM
rex1one's Avatar
rex1one rex1one is offline
Send a message via AIM to rex1one Send a message via Yahoo to rex1one
Warped Rotor, or something worse?
Front drivers side wheel makes an oscillating scratching sound (like metal being sandpapered) when turning right. Is this the sign of a warped rotor, or something I haven't thought of?
Of you haven't broken it then you haven't gotten any use out've it.
Old 09-03-2004, 02:48 PM
jayson716 jayson716 is offline
Re: Warped Rotor, or something worse?
check you pads i had that problem when i had low pads and when you turn they move just enough so the bar on the pad that touches the rotor is touching. or it could be a bearing but i would bet on the pads.
-Jay Jones
Team DROPZONE
Vice President
Old 09-03-2004, 03:09 PM
Sight N Sound's Avatar
Sight N Sound Sight N Sound is offline
99.9 percent it sthe wear indicator on the pads meaning they need changed. It will start to get worse and will happen no matter what way the wheel is turned. If you wait too long you could gouge the rotors
Old 09-03-2004, 04:00 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
pads are easier and cheaper, try them first. if that doesn't fix it, its the hub bearing.
Old 09-03-2004, 07:15 PM
rex1one's Avatar
The pads are only about 2 months old. The tab is still 3/4" from the rotor and there's no abnormal marks/scrappings on the rotor (just normal pad rub marks)
That was the first thing I checked.
The scratching sound changes with the speed. Like just one part of the wheel or rotor is making it.
Scratch... Scratch... Scratch... Scratch... Scratch... Scratch...
But I can still hear it when I'm braking (that's why I'm questioning the warped rotor theory that my coworker gave me).
Old 09-03-2004, 07:26 PM
richtazz's Avatar
if your brakes don't pulse when stopping, it's not a warped rotor, I would put my money on a hub bearing
Old 09-03-2004, 07:31 PM
rex1one's Avatar
How easy is that to fix? I've never gone beyond the rotors on any of my vehicles, but I'm used to doing my own work.
Old 09-03-2004, 07:38 PM
richtazz's Avatar
Once you get the brake caliper and rotor off, all you have left to do is remove the axle nut (30mm socket) and the 3 bolts securing the hub bearing to the spindle (t55 torx bit). there is a hole thru the hub between the lug studs that you rotate around until it lines up with the torx head bolts, remove them one at a time and the hub will be in your hands. They only run about $50-$60 at Auto-Zone or Advance. Make sure you tighten the axle nut to spec (180 ft/lbs) and don't use an impact, use a hand torque wrench
Old 09-09-2004, 03:34 PM
rex1one's Avatar
Here we go... I took it apart today to check on whether it would made the sound with the rotor off, whether the wheel span freely, etc... I wanted to make sure before I spent so much on a part.
But for the life of me I couldn't get any scratching sounds while not driving.
I'll skip to the end: After 30 minutes of looking like an idiot in my apartment lot I discovered that the lower tip of the Rotor shield was rubbing up against the rotor on right turns.
But I'm happy. I'd rather have a little pie in my face than be out 50-70 bucks.
Thanks for your help guys. Maybe this thread can help someone else someday.
Old 09-09-2004, 10:29 PM
cool glad it was a simple fix.
Old 09-10-2004, 01:12 PM
richtazz's Avatar
excellent, another perfect example of the K.I.S.S. principle. Keep It Simple, Stupid. Not saying you're stupid, (I didn't make up the acronym) it basically means to not outhink yourself and look for expensive problems first, go with the simple and free first. Seriously though, I'm glad you fixed it, and it didn't cost anything.
