Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 09-03-2004, 01:48 PM
daddie30 daddie30 is offline
Angry car won't start
I changed my steering column in my 95 monte. It ran before I changed it.
know it won't even turn over. if anyone can help me running i would appricate it alot.
Old 09-10-2004, 11:20 AM
robz84monte robz84monte is offline
sounds like and electrical/wiring problem to me. take back apart as much as you need to to check all the wires, connectors, and grounds.
on a side note do your interior lights, radio, ect. work?
Old 09-11-2004, 11:26 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: car won't start
does your car have a chip in the key? If so, your security module isn't recognizing the new key. If it doesn't, like Robz asked, do you have any power at all when you turn the key, or is the car dead?
Old 09-11-2004, 09:42 PM
Re: car won't start
All the pwer works except the key I found out it was the key with a differnet code. I need a new key with the old code. thanks for the reply.
Old 09-11-2004, 09:43 PM
Re: car won't start
thanks for both replies it helped.
