Old 09-03-2004, 02:02 PM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
Bigger the better (cams)?
the stock cam gear on a d15b2 has around 32 teeth and the stock cam off of a SOHC 84 prelude motor has around 42.... should i experiment after i build my my motor, with the bigger cam gear?
my block s currently in pieces and im building it for boost.
some people say the d16a6/SI cam gear on a d15b2 dpfi to mpfi swapped is a more power choice to go.
is the si cam gear bigger?
how about aftermarket cam gears like AEM and skunk 2s. are they bigger?
Old 09-03-2004, 02:11 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Bigger the better (cams)?
I don't see how just getting a bigger cam gear would help, now if you got a bigger cam sure.
Old 09-03-2004, 03:48 PM
Kven's Avatar
Kven Kven is offline
if you dont change the gear on the crank, but put bigger cam gears, your gonna fuck up your timing real bad. the gears are design/sized so that the cams are turning at half the speed of the crank.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 09-03-2004, 05:18 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Just to add...skunk2 cam gears are much better than AEM. 6 bolts vs 3 bolts. Skunk2 doesn't slip like some AEM cam gears does.
Old 09-03-2004, 05:32 PM
Kven's Avatar
AEM has 5 bolt ones now(they discontinued the 3-bolt i think)
1988 Honda CRX DX
Old 09-04-2004, 02:45 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
that sucks, I have a brand new pair of 3-bolt gears sitting in my garage from a year ago Now I doubt I'll be able to even sell them.
Old 09-04-2004, 02:49 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
if u get adjustable cams gears...don't try and do it urself unless u know what ur doing b/c u can cause ur engine to lose hp rather than gain
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 09-04-2004, 12:07 PM
mellowboy's Avatar
Re: Re: Bigger the better (cams)?
Uh yeh buddy its called tuning!
Old 09-04-2004, 12:48 PM
CivicSpoon's Avatar
There is no Spoon
Sure you could, find a newbie they'll buy anything
Old 09-04-2004, 02:23 PM
Crippy's Avatar
Crippy Crippy is offline
espeacially if you tell em they will gain 7- 15 whp from them .... HAHA
2001 GSR ,
94 jdm b18c sir-g swap , i/e !!
