Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-03-2004, 08:48 AM
juicy19 juicy19 is offline
Send a message via AIM to juicy19
Starting troubles
Hey guys. First off, my car - 5th gen prelude 34,000 milses - I've been noticing lately that my car won't start unless the clutch (stock) is pressed all the way in. The engagement point is well sooner than the point where it needs to be to start the car.
I don't have a problem starting the car, its just the clutch needs to be pushed in all the way to the floor (with maybe a half inch left) for the car to start. I'm worried that it'll get to the point where the clutch won't go far enough to get the car started.
What can I check or do to see if there is a problem?
2001 Honda Prelude SH
DC Header
3" Intake with K&N
GReddy Exhaust
Unorthodox Racing Pullies
JET enhanced ECU
10.3 OBX Plug Wires
Old 09-03-2004, 09:15 AM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
The clutch is supposed to be depressed all the way to start the car when it comes stock. You can tweak the sensors if you want to be able to start the car without pushing it all the way in.
Old 09-03-2004, 09:17 AM
Re: Starting troubles
It seems like its gotten farther down than it used to be.
DC Header
3" Intake with K&N
GReddy Exhaust
JET enhanced ECU
10.3 OBX Plug Wires
Old 09-04-2004, 12:28 AM
hundahunta hundahunta is offline
check and make sure that the switch is properly secured. also some older hondas have a plastic/rubber insulator or spacer where the clutch safety switch contacts the pedal check if your vehicle has one and is missing it.
