Old 09-03-2004, 08:19 AM
rusher75's Avatar
rusher75 rusher75 is offline
Banned
Send a message via AIM to rusher75 Send a message via Yahoo to rusher75
radio not wroking
i have a 95 s-10. the radio dont work in it. when i got the truck, it had a cd player that didnt work (i dont know if it works). so i put in my poineer that i know that works and nothing. i checked the fuses and they are good. can anyone me
Old 09-03-2004, 12:32 PM
busa_4 busa_4 is offline
Re: radio not wroking
its time for you to look at a wiring diagram to see what powers the radio. some vehicles have more than 1 circuit powering the radio that is not listed in the fuse panel. check every fuse in the fuse block first.
Old 09-03-2004, 01:41 PM
rusher75's Avatar
Banned
all the fuses are good. checked them all. where would i get a wiring diagram at?
Old 09-03-2004, 01:43 PM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
www.installdr.com or get a haynes or chilton's And please get a multimeter to test wires, as you are not supposed to use a test light on the newer airbag equipped models. Test lights could trigger deployment. -Chris
Old 09-03-2004, 02:12 PM
rusher75's Avatar
Banned
hey thanks alot, ill check them out, and thanks for the heads up
Old 09-05-2004, 07:46 PM
just some advise. your aftermarket radio needs 3 wires to turn on. ground, 12v constant (12v all the time), and 12v ignition (12v only when ignition is on). test all the wires and see which one/s you dont have. look for the thicker wires. becarefull as your testing live wires! if you dont have power to the 2 power wires then you will need to stare at the wiring diagram to determine the fault. do you know how to read a wiring diagram?
Old 09-05-2004, 08:16 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
This sounds like a bad fuse still.
Check all the fuses carefully.
Old 09-05-2004, 08:32 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
how did you/they wire the radio in? did they get an adapter or just cut the plug off and re wire it? did you check the fuse on the radio? there could be a fuse under the hood that you need to check. the list of possibilities is almost endless. i know on a lot of the newere aftermarket cd players, the antenna has to be plugged in as they use it as a ground source. check that. and invest in the multi meter and test all positive power wires for the radio. did you check all of the fuses in the block or just the radio? they might have pulled a power wire from say the 12V adapter. that fuse might have went.......just my .02
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
