Old 09-03-2004, 08:12 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Unhappy I can't win..
Well I get my NEW head in, it looks like it's been sitting in an attic since 1995, like spider webs, and insects are dead in side of it and shit. LOVELY anyway I clean it all up and get everything bolted back up, and one of my bolts on the end of the camshaft holder breaks off. Great. None the less I put my valve cover back on, and I was trying to get one of the rubber parts out under the head of the bolt, with my hand...and it broke off also. Lovely. What f*&king luck. So how the hell do I get those broken bolts out of my shit?
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 09-03-2004, 08:53 AM
doug294 doug294 is offline
Send a message via AIM to doug294
Well at the shop if this happens they just spot weld a piece of metal on and twist it out. Is it drivable? If it is broke off down in there and you can't get it and it is also undrivable you might want to take a piece of metal (anything that will fit down there) and "weld" it on to the broken bolt with some JB weld. Hopefully it will hold tight enough for you to unscrew the bolt.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 09-03-2004, 12:23 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Re: I can't win..
go to sears, craftsman has a set of broken bolt extracters, drill a hole in the bolt, make sure its centered, insert the exrtacter and twist it out, be careful notto break the extracter off in the bolt though, b/c those pappies are hard let me tell ya.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 09-03-2004, 03:07 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: I can't win..
Jeef is correct once again on the bolt extractor.
Old 09-03-2004, 10:52 PM
quiXilver's Avatar
Re: I can't win..
yea now I got everything running, for about 10 mins, the the headgasket started leaking...guess 3rd time is a charm...I need to replace it then see what happens.
B18A
Old 09-03-2004, 11:05 PM
Forunn Daberator
Re: I can't win..
you used the same head gasket over again?
Old 09-03-2004, 11:30 PM
quiXilver's Avatar
Re: I can't win..
yea i'm a fuckin tard, i spent like 50 bucks on this awesome 3 layer metal head gasket and I sprayed the shit out of it with copper spray so i thought it might hold up again, but I guess not...i know i'm dumb oh well i'll replace it again tomorrow
B18A
Old 09-03-2004, 11:46 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: I can't win..
man looks like your haing the luck i had with mine after i threw a rod bearing it was all down hill...here it is now car finally running two months later...only pays off in the end in between sucks really bad...i know how you feel man...wish you luck
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 09-04-2004, 01:20 AM
Forunn Daberator
Re: I can't win..
heh, sucks to be you. Hey I might be able to buy your head afterall, did you ever find out the shipping price?
Old 09-04-2004, 06:00 AM
quiXilver's Avatar
Re: Re: I can't win..
kinda, but with the hurricane comming nobody is open so I can't ship it untill this whole thing blows over, so we're gonna have to wait untill after that.
B18A
Old 09-04-2004, 05:02 PM
itechengineers itechengineers is offline
Send a message via Skype™ to itechengineers
Re: I can't win..
hey hey how strong is that bolt extractor from craftsman/sears? I've never had the chance to play with it...
the route i've always taken was drilling and re-tapping the hole with the proper metal fittings/threads. it does hold up very good.
for a little info/ tapped a block (a head bolt got fecked) and everything is fine under boost (1.6/ turbo/ dynoed around 190/stock 7psi spring) the tap held and is holding well.
Old 09-04-2004, 06:34 PM
quiXilver's Avatar
I'll check and see how good it is since I work at sears.
B18A
Old 09-04-2004, 10:09 PM
Forunn Daberator
Re: I can't win..
there pretty damn strong, They work quiet well also.
Old 09-04-2004, 10:20 PM
Darb 2k's Avatar
Darb 2k Darb 2k is offline
yup they work awesone. same with that stripped screw version. saved my ass many times
'89 Civic CX
Old 09-05-2004, 05:18 AM
89HatchSiET 89HatchSiET is offline
Re: I can't win..
sorry to hear about your bad luck man, I'd just buy a new head gasket, and if that didn't work, I'd drive w/that motor until it died or blew up, which would give you time to save up for a new sohc motor to swap in, I know a guy who had a blown head gasket in his EF Hatch and drove it for like 2 months until it died, then swapped a Vtec head on it, and it ran fine
