Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 09-02-2004, 10:21 PM
GMP440 GMP440 is offline
Post Cannot turn ignition switch backwards to lock steering wheel.
1991 Crown vic. Cannot turn ignition switch backwards to lock steering wheel. Has anyone had this problem? What is the fix for this?
Old 09-03-2004, 02:40 AM
Warren'74 Warren'74 is offline
Send a message via MSN to Warren'74 Send a message via Yahoo to Warren'74
Re: Cannot turn ignition switch backwards to lock steering wheel.
What do you mean exactly?? Does the ignition switch actually turn off, so that you can remove the key??
Old 09-03-2004, 11:17 AM
dxrflyboy dxrflyboy is offline
Look for problems with the trans. selector. If it doesn't go all the way into Park, the lock cylinder won't turn all the way to the locked position.
Old 09-03-2004, 06:43 PM
Lightbulb
The trans selector has no problems. You can put it in park and all the other selections. The engine can be shut off. The lock cylinder will not go past the off position in order to actuate the lock. I tried a different
lock cylinder, but still have the same problem.
