Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 09-02-2004, 04:21 PM
tiger1210 tiger1210 is offline
Question oil weight
My 03 Grand Marquis calls for 5/20 oil weight. I think this is too thin for Southern California. Any ideas? Please emial me your answer at [email protected]
Old 09-03-2004, 10:21 AM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: oil weight
5w20 oil used in these motors is a synthetic blend and is good in all temp conditions
-=-=-DANE-=-=-
Old 05-22-2006, 05:52 PM
richter111 richter111 is offline
Re: oil weight
Make sure you stay with the 5W20. When I worked for the Ford dealer, we had alot of cars coming in saying they were running rough right after they had the oil changed. Turns out they were going to the quick lubeand having the wrong weight of oil being put in. The bearing tolerances on these vehicles is alot closer. The thinner oil allows for proper lubrication. Thicker oil just wont do the job.
Hope this helps
Ric
Old 05-22-2006, 08:40 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
Re: oil weight
that makes scence but in my 92 it calls for 5w30 and im runnin 10w30 due to oil consumption would this cause an idleing rough prob?
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 05-23-2006, 12:41 AM
Re: oil weight
It could, but I would check out your EGR valve. They gunk up pretty quickly especially if you are burning oil.
Also, invest in a code reader, you can pick one up ay your local parts house. They run about $30.00 or so and are worth their weight in gold. With a code reader you can pin point your problems in about 10 minutes or less
Hope this helps.
Old 05-23-2006, 09:27 AM
Re: oil weight
i work at a shop so i use the one we have and im not getin a cel but i guess i could give the egr passageways a try i was getin an egr code but i toke a mighty vac to it and un stuck it and its worked fine but thanks
Old 05-26-2006, 10:49 AM
defrost3 defrost3 is offline
Send a message via Yahoo to defrost3
Re: oil weight
Hey I have an 86 GM, but I have a slow oil leak (not sure from where, I put it in the shop and they claim to have fixed it, but it still leaks), anyway, I have been running 10W 40 in it, I figure since it's so hot here in mississippi, this might slow down the oil leak with the thicker oil. This won't hurt my car will it? Also there is some kind of whitish gunk where I put my oil in, how can I get rid of that?
Old 05-26-2006, 05:31 PM
Re: oil weight
The white gunk in your cap and fill area can be a sign of a blown head gasket. When the engine is cold , check the radiator fluid, if it is oily its a good bet you have a blown head gasket. Also does the oil look milky to you? Its also another sign. However, if the car is driven in very cold climates, ie like mine in Wisconsin, winter temps can cause the water to condense in the fill tube causing the white gunk. When the weather warms up, it should burn off. Good luck
Old 05-27-2006, 11:59 AM
Re: oil weight
Thanks for the great news, fortunately though, my oil does not look milky and the radiator fluid isnt very "oily" looking. But just to be sure would there be any other symptoms I should look for? There is this type of gunk in my power steering fill canister also.
