Old 09-02-2004, 01:56 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
good oil is important, how important is oil filter?
I know mobil 1 is way better than quaker state, for example.
What I dont know about is oil filters. Are there different grades/types? Also, are the differences in running good vs average quality filters just marginal, or substancial like the oil itself...?
The daily driver. The weekend cruiser. The lazy shop hog.
Old 09-02-2004, 02:09 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: good oil is important, how important is oil filter?
oil filters are veary imortant. factory oil filters have plugs that stop the oil from draing out of the filter and into the pan when the cars not running. some gereric filters dont. and thats just not good to start a car without oil in the filter.
DSM geek
Old 09-02-2004, 02:55 PM
joemathews's Avatar
joemathews joemathews is offline
Filters are easily as important as oil, if not more so. If you're running Mobil 1 with an oil filter that leaves metal shavings in your oil, don't count on your engine lasting long!
1996 Eagle Talon
Old 09-02-2004, 04:40 PM
kjewer1 kjewer1 is offline
AF - Advisor
Right on. Filter is very very important. I only trust OEM or Pure1. A local guy used to work somewhere testing these things. Fram is the worst. And be sure to safety wire the filter on. Cant do much filter if you blow it off (happens on my car all the time).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-02-2004, 04:41 PM
Shpyder's Avatar
Moderate moderator
any good brand names you'd suggest?
Old 09-02-2004, 04:53 PM
AF - Advisor
Re: Re: good oil is important, how important is oil filter?
OEM is stock mitsu filters for anyone not familiar with that term (Original Equipment Manufacturer), from the 1g turbo cars (the larger filter). Pure1 is made by Purolator. Not the cheapest at 5-6 bucks, but well worth the added cost based on what I said above.
Kevin Jewer
Old 09-02-2004, 05:03 PM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
hmm so fram sucks? maybe i should buy a diferent one next time.. only reason iv been buyin fram is that sweet sure grip crap on the bottom of em...
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 09-02-2004, 05:06 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
http://minimopar.knizefamily.net/oilfilterstudy.html
For Sale 98 Eclipse GS, 5 spd
Old 09-03-2004, 06:06 PM
Shpyder's Avatar
Moderate moderator
I just installed a K&N oil filter....sound g0od?
Old 09-04-2004, 01:25 AM
AF - Advisor
I'm not sure how well they filter, but they alledgedly have provisions for safety wiring it on. Which is cool.
Kevin Jewer
Old 09-04-2004, 03:22 AM
joemathews's Avatar
I could have sworn I read something about K&N filters being sub-par for our cars...I am almost certain I read it on Tuners, but I can't find it now that I'm searching for it. I don't think it will be a big deal for one or two oil changes. As long as you keep an eye on your oil level and quality, that's all you can really do. Like Kevin says, OEM filters are the most highly recommended!
1996 Eagle Talon
Old 09-04-2004, 06:28 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I have been running the K&N for the last 30xxx miles with no problems at all. Before that I tried a bunch of others and didn't really like them that much. As for the safety wiring....wow, I never knew what those 2 holes were at the end of the filter (on the big 1" nut at the bottom for easy removal).
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
