Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 09-02-2004, 08:51 AM
bcopeland bcopeland is offline
2001 Yukon XL Erratic Idle
At idle, my Yukon can sometimes idle erratically. I had the fuel injectors cleaned, new spark plugs, air filter, fuel filter - all to no avail. Sometimes it just idles great and others it is erratic. The erratic idle also can cuase the AC to blow warm. Any thoughts?
Old 09-03-2004, 10:23 PM
farkas3343 farkas3343 is offline
denali rough idle
The throttle plate is sticking. With the key off push open the throttle plate and clean it out with carb cleaner and a rag to wipe off the carbon buildup. This is usually caused by using cheaper gas. Try to run a tank of the new shell premium, it has a deturgent in it to clean the injectors and the intake valves. I noticed a difference in mine after I cleaned the thottle plate and running the premium gas.
Old 09-04-2004, 06:52 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 2001 Yukon XL Erratic Idle
A good cleaning of the throttle body should take care of your problem.
There are a couple GM TSBs regarding this concern that include a calibration update for the PCM.
As far as running premium fuel in your truck..don't waste the money. Your truck is designed to run on 87 octane..using a higher octane fuel can cause some cold start driveability issues
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-15-2004, 11:14 AM
Well, I cleaned the throttle body and it seems to run like a charm. I'll keep you all posted. Thanks a bunch!
