Old 09-02-2004, 07:59 AM
riff22 riff22 is offline
gauge says lean????
95 tsi running lean what should all be checked? its this fine to drive? gauge stays in lean at wot.
Old 09-02-2004, 03:45 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: gauge says lean????
Cant go by that guage, you have to verify it with something else. Could be a failing sensor, fuel filter, pump, preturbo/post mas intake leak, to name a couple. But be sure its a real problem before you go trying to fix it. A logger would be nice. A WBO2 will do nicely, if you're a baller and can afford to just hop on the dyno or buy one.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-02-2004, 04:30 PM
mavisky mavisky is offline
Send a message via AIM to mavisky Send a message via MSN to mavisky
what are your modifications? what boost are you running right now?
91 grand am -> daily driver
92 eagle talon -> toy car
dsmtuners moderator
Old 09-02-2004, 04:57 PM
no mods exept for dump tube cut and the bcs mod. im running 14 or 15 psi
Old 09-02-2004, 07:29 PM
sounds like you need a 190lph fuel pump, that'd flow the extra fuel you'd need assuming your injectors aren't clogged or dirty. the big problem is that your blinky blinky air fuel techno dance guage isn't accurate at all. what you really need is datalogging software to show you just what's happening with the car.
dsmtuners moderator
Old 09-03-2004, 08:18 AM
ok thanks much
