Tensioner Pullley
I would lick to change the pulley on my tensioner arm but I undersatnd they can crack easily.
Are there any tricks? |
Re: Tensioner Pullley
I'm wondering the same thing . . .
Do you turn the nut clockwise to remove the pulley since turning it counter-clockwise only pivots the mechanism to release tension? |
I replaced the pulley a few weeks ago. Turn it clockwise to loosen it. Don't forget to take the belt off first. Very easy job. However it didn't fix my rattle.
A rattle in that area could be either a water pump bearing or the timing chain itself.
*shivers to the tought of it* i heard that a water pump is not so fun to do on a PA i hope i dont do mine soon....
Deadring |
I also changed my water pump last year, about $65.00 for a rebuilt, next time I think I will spring for a new one JUST Because of what's involved. The hardest part to me was cleaning the block good enough but I got it done with no leaks, If you do the pump be aware some cars have a plastic/PVC type water bypass fitting in the intake manifold and when I touched it, It broke off flush with the manifold and I had to drill it out, so if you can change this before it breaks you are extremely lucky, and a short heater hose type bypass hose running back to the top of the water pump, Mine was dripping and thank goodness I saw it while I was changing the Alt. So I would suggest changing both the fitting and the bypass hose, they are famous for breaking due to high heat,( The new one's are Metal and I think a dealer item as they have a grove for an O ring machined into the top of the threads so it won't leak ) At least mine hasn't and it's been a year now Mine is not a PA it's a LeSabre 94 with 216,000 and going strong. (For the Water Pump removal)The Engine mount also has to come off both halves (Block and Body)not a big deal just a pain to have to support the engine on a jack, and when the mount is off jack up the enging just enough to get the pump off, Hope this helps. Rick PS I know it looks like only one half the mount needs to come off but, There's a hook built into it to stop the engine from torqueing up if the rubber mount should fail, That's why the whole mount has to come off, it hooks into the body half of the mount, Bot that looks confusing I hope not ! any questions please feel free to E-mail me directly [email protected] |
