Old 09-02-2004, 02:53 AM
winlo408 winlo408 is offline
is it true?
is it true once you use synthetic oil you cant go back to regular motor oil because your engine is use to it? thats what someone told me at a parts store, just wanted to varify.
thanks
Old 09-02-2004, 05:22 AM
phoenixitc phoenixitc is offline
Re: is it true?
I had a Jiffy Lube tech tell me the same thing.
Old 09-02-2004, 07:18 AM
HONDA_99 HONDA_99 is offline
Re: is it true?
did you asked why is that?
Old 09-02-2004, 08:27 AM
94hondaacc 94hondaacc is offline
so what happens if you buy a car at an auction, and you dont know the history of the oil used? come on!!!
Old 09-02-2004, 08:44 AM
Re: Re: is it true?
Nope, because I didn't accept his story and felt he was trying to push a more expensive option, just as they do with the 75k oil that costs $10 more than regular oil.
Old 09-02-2004, 11:03 AM
phantastic1 phantastic1 is offline
Re: is it true?
there is no harm in switching...as long as what you are switching back to at least meets the oem specs. however fully syn oil keeps the engine lubricated alot better under certain driving conditions over regular. it doesn't break down as easily as regular oil would. but if you are just using your car as a daily driver and keep up w/ it's oil changes you should be fine.
Old 09-04-2004, 01:20 AM
Accord_boy619 Accord_boy619 is offline
Ive switch back n fort usin syn then reg oil. They only thing I notice is that my vavle train is not as noisy when I use syn(Valvoline). In my opinion, if u aint racin or drivin where yur engine runs real hot all the time, you dont need syn.
97 Tahoe 2dr- raise = http://www.cardomain.com/id/tahoe_boy619
98 Accord 4dr-droped = http://www.cardomain.com/id/accord_boy619
Old 11-01-2004, 11:50 PM
WhyteAccord WhyteAccord is offline
Re: is it true?
Synthetic oil permeates the walls of the cylinder to provide excellent lubrication. If you go back to standard oil after using synthetic, the smaller molecules in standard oil will literally slip by the rings because the synthetic oil has already become embedded in the cylinder wall. This will cause your engine to smoke like crazy.
And that's Why!!!
Old 11-02-2004, 09:30 AM
HILARYDUFF!! HILARYDUFF!! is offline
Re: is it true?
I have a friend who works for ford he help design the a/c unit and how it would affect the engine power when swithced on...he has a chemical engineering degree and a masters in mechanical engineerig ...he told me that if you use synthetic in a vechicle listed for non synthetic oil such as the honda accord..your gaskets can become worn after time and leakage can and will occur...i still use full synthetic ahahahaha....
Old 11-02-2004, 09:32 AM
Re: is it true?
oh yea he help design that on the new ford 500 and he also designed the transmission on the new t-birds and he helped with the new ford trucks he designed the insulation..that is why they are the quietest truck ever...
Old 11-02-2004, 12:55 PM
ProMan ProMan is offline
Re: Re: is it true?
And that's Why!!!
What you said is totally bullsxxt.
Old 11-02-2004, 01:40 PM
Igovert500's Avatar
blue + red light magnet
Re: is it true?
The rumor I've heard is that synthetics have additives that expand your seals...when you switch back to regular oil, the seals can shrink and cause leaks...I think this is BS, there have been a few threads in the Technical section of AF regarding this subject though...so if you want to read their opinions, I suggest you do a search.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-02-2004, 11:30 PM
imports_only1 imports_only1 is offline
Re: Re: Re: is it true?
What he said is all true.
Old 11-03-2004, 09:16 PM
scubawrstlr's Avatar
scubawrstlr scubawrstlr is offline
Send a message via AIM to scubawrstlr Send a message via MSN to scubawrstlr Send a message via Yahoo to scubawrstlr
Re: is it true?
very true indeed
I've only just begun...
