Old 09-02-2004, 01:30 AM
phixion009 phixion009 is offline
Can't figure out what's wrong, it won't start!!
I was driving and my car(90 civic hb si) sputtered out and died. Checked for spark and nothing, checked for fuel, yes getting fuel. Replaced distrubutor and still nothing. I charged my battery becuz it was cranking really slow, still cranking slow with 12.5v. Spark plugs smell like gas, oil smells like gas, I need help. No clue on what to do and too poor for a mechanic. PLEASE I NEED SOME ADVICE!
Old 09-02-2004, 11:21 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Can't figure out what's wrong, it won't start!!
did you replace the coil with the dizzy? did you check the cap and rotor? Also, ur probably not gonna see a spark or much of it anyway if you're car is not turning over quick enuff.
BTW...just because a car has enough voltage doesn't mean anything....it can still have a low current.
Check those things and boost it to another cars battery and then try to start it.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 09-02-2004, 11:29 AM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
If your oil smells like gas, you could have a compression problem.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 09-02-2004, 11:40 AM
bambam89lx's Avatar
AF - Advisor
if your saying you opened ur oil cap up and you smell gas...that's normal for a car that is getting flooded with gas from not starting.
Old 09-02-2004, 04:12 PM
Thanks for the input guys. I replaced the dizzy, new cap, new rotor, and new coil. It was cranking strong for about two days with no spark before i got the new dizzy. By the time the new dizzy arrived is when it was cranking slow, I tried boosting it with same results. Right now I took the plugs out and valve cover off to try to let the gas air out. Is there anything in the mean time i could check for problems? Ground wires, electrical or something?
