Go Back   Automotive Forums Car Chat > Subaru > Forester
Old 09-01-2004, 11:25 PM
cat5 cat5 is offline
Question Forester XT oil changes
I am going to try doing my own oil changes on my new 04 Forester XT.
I watched my mechanic do my first one, and there was a plastic (very soft) cover with a flap/door that had to be opened to get to the filter and plug.
He had trouble with it, because the pins were hard to remove. He was using a sort of nail puller type of tool but the plastic was so soft that he could not get a grip on the pin, which is of course plastic.
I am wondering what is the best way to open the flap.
Also, I will buy some extra pins to replace any that break. I suppose I can get these at CarParts.com or maybe a local retailer.
I will also be looking for a "no-mess" container to drain the oil into and then pour it back into the bottles in which the new oil came for recycling.
I would like something covered, with a spout.
Any ideas?
Thanks
cat5
Old 03-13-2005, 06:16 AM
Bossman Bossman is offline
Cat5,
All of the things you mentioned for changing your oil can be obtained at any major name auto parts store; no problem.
Will you using synthetic or petroleum based oil?
Happy motoring!
Old 03-14-2005, 08:35 AM
SabreKhan's Avatar
SabreKhan SabreKhan is offline
The middle pedal is bad
Re: Forester XT oil changes
A screwdriver will get under those pins pretty easily. You just have to pry them loose. You'll eventually break one or more of them, but until it's actually causing the plastic to sag I wouldn't worry about replacing them.
Look at the teeny picture of my car!
2004 Impreza WRX (SCCA DS 519)
2000 Saturn SL
Old 05-31-2005, 10:12 AM
ctp_mechanix ctp_mechanix is offline
just fuck it.
when i worked in a shop for i came across an 04 forester, not an xt but it still had the flap. screwdriver in, push up flap down. nothin broke. worse case scenarnio you lose the flap, 02's have no flap and there is still the same opening. so yeah, ur choice. and on a side note, since the car is turbocharged. and i presume your doing your own oilchanges so u must be a bit of a motorhead, change ur oil every 2000-2500 and use synthetic, or drive it like a grandma
