Chipping ecu
I just got shunk ecu chip and just installed it. It seems to me that my integra is run just the same before the chip, no extra hp. Does anyone know if i have to get some tuning done in order to have get the 15-20 horse power that a mod chip should give me. Is there anyway to test to see if the chip is working other then just getting on a dyno.
Re: Chipping ecu
nope, chips are usually a waste of money, how much did you pay for it?? most of the time companys that make those chips, just make random guesses as to what your settings should be, the absolute best way is to tune it with a wideband and a VAFC or something to that effect, a standalone like a hondata would be best but those are expensive and cost more to tune because they are so precise.
Re: Chipping ecu
95' LS Integra 5spd DC Header (4-2-1) HKS Super Dragger Exhaust Skunk2 Short throw shifter Ground Control Coilovers Strut Bar -SOON to be putting in a JDM B16 hydraulic tranny with lightened flywheel and stage III clutch -SOON to be "home made" turbo charging (goal = 12psi) -GOAL = 250-300hp with stock internals(probably not reachable) |
Re: Re: Chipping ecu
Re: Chipping ecu
Its not a waste! Its only a waste if your motor is STOCK! Get some aftermarket cams/cam gears and get it tuned. You might see more than 20hp gain with a good tune.
Re: Chipping ecu
if you have aftermarket cams and cam gears you should see better than a 20hp increase just from that alone, as long as its tuned. but i promise you mellowboy, those chips are a waste, they are best guess and they have noidea what your car needs for the modifications it has, so why waste your money on something that wont show the full potential of the car?? thats why you need to program your own unit, or let a competitent motor tuner do so.
Re: Chipping ecu
Ok from the other thread u been sayin the samething. I'm gonna say it again...those engine management units are not needed when the motor is not heavily modified! How many times do i have to say it to get it through your head? Whos gonna spend 550 -1400 just to tune a nearly stock motor? Chip ecu does work with TUNING!!! My friend gain 8 1/2 lbs of torque and saw 18 hp with Kenji ecu! He only spent 250 on the damn thing!
Re: Chipping ecu
Obvisously u dont know shit.
