Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 09-01-2004, 06:39 PM
aplummer aplummer is offline
Check Engine on/off
Anyone else have or had this problem? I have a 1997 Jeep Wrangler.. sometimes very difficult to start. Now when I run for a while and the engine gets hot, the CHECK ENGINE light comes on. When I let it sit and the engine cools, the light goes out.
Any ideas? thanks..
Old 10-01-2004, 10:57 PM
Axe91CVC Axe91CVC is offline
Re: Check Engine on/off
i have this exact same problem
just normal driving to and from my day job the 1997 wrangler sport is fine......no problems
however during my second job ...which i deliver pizza at night
....the engine gets hot and the light comes on
the very next morning when i turn the jeep on the check engine light is gone.
( it just started doing this about 2 or 3 weeks ago )
and occasionally the next morning the light will still be on.
my "GUESS" is the oxygen sensor.......
looked at the jeep owners maual......says there could be some problem with the exhaust, or transmission?
Old 10-04-2004, 10:44 AM
MYBBYSAJP MYBBYSAJP is offline
Send a message via AIM to MYBBYSAJP
the next time the light comes on, use the trick on this sight to find the codes for the problem, the site will also tell you what the codes mean, it really works and can give you a head start on fixing the problem!
http://www.webejeepin.com/Check-Engine.htm
Old 10-05-2004, 01:49 PM
gswath gswath is offline
Send a message via AIM to gswath Send a message via MSN to gswath Send a message via Yahoo to gswath
check engine light
i have a 99 wrangler and the check engine light is on as well. i tried the turning of the key and got nothing. is it different for this model or am just doing something wrong?
Old 10-06-2004, 08:54 AM
Blair25 Blair25 is offline
I would first suspect the O2 sensor, is your idle running different? This sensor is easy to change yourself and should be replaced once a year. It is right below manifold, if you haven't changed this then try it. It could be burnt out which will tell your motor the O2 coming out of your engine is rich which will tell your computer to adjust engine mix.
Old 11-14-2004, 01:50 AM
well i still havent changed out the oxygen sensor
and the light is still comming on only when the engine is running extremely hot from a long night of pizza delivery.....and this funny thing keeps happening as well.......when the engine is running way hot..i smell what seems to be an electrical burning smell...like burning wires or burning plastic.......
i did go to autozone and had then do a computer diagnostic .....the engine light code flashed a 37
any ideas as to what this could be??
and what the heck is this burnt electrical wiring smell ???...has anyone experienced this??
Old 01-31-2005, 04:02 PM
GreenJeep10's Avatar
GreenJeep10 GreenJeep10 is offline
Re: Re: Check Engine on/off
37 Relationship between engine speed and vehicle speed indicates no torque converter clutch engagement. An open or shorted condition detected in the torque converter part throttle unlock solenoid control circuit. Incorrect input state detected for the Park/Neutral switch. Auto only. I hope this helps alittle but as what to do to fix it......may need mechanic.
