Old 09-01-2004, 06:27 PM
accordish accordish is offline
92 starting problem
New to this forum! So hi y'all.
I have a 92 Accord EX that has trouble starting on warm days. If the car doesn't start the D3 light blinks on and off. I can wait about 2 or 3 minutes and sometimes it'll start sometimes it won't. Also if I go on short distance trips and try to start the car again I'll have to go through this same annoying routine. The car kinda has the feeling that there isn't enough gas getting to the engine to start.
Any advice would help!
Thanx!
Old 09-01-2004, 07:31 PM
adrenalin26 adrenalin26 is offline
Everyone With A 90-93 Accord Read
Hey there, it's probably your MASTER RELAY. I had the same problem and so did my friend. I searched the net for an answer and always came up with master relay. I took mine out, resoldered it and it hasn't done it again. That was over a year ago. The Master Relay is right under the dash on the drivers side (on my '90 anyway). You just take it out, open the cover, resolder all the connections at the top of it and it's good as new. Apparently the solder they used in Malaysia or whatever was sub-par and when it gets old the solder disconnects after it gets hot. When it cools (usually 5-15 minutes) it will work again.
Go to this link! You will thank me. It is an extremly easy repair and works great. I was sceptical but it worked when Honda dealers, mechanics and everyone else couldn't figure it out. Don't know why more people don't know about this. Everyone I know that has a 90-93 Honda Accord has this same problem. Usually only does it when the car has been driven a short distance.
http://www.markl.f9.co.uk/howto/ele.../main-relay.htm
They go into a lot of detail but I just took mine out, resoldered it and put it back in.
Hope this helps,
Tony
Old 09-01-2004, 07:33 PM
The Internet address
The address didn't work. Here it is again.
http://www.markl.f9.co.uk/howto/elec...main-relay.htm
www markl.f9.co.uk/howto/electrical/main-relay/main-relay.htm
Old 09-02-2004, 04:24 PM
Re: The Internet address
You are my hero! Thanx alot, that link was what I needed. Such an easy fix too.
Peace in the Middle East
Old 09-02-2004, 06:59 PM
hope it works
no prob. Hope it works. It worked for my car and a couple other people I know. We all had the same problem. I searched forever, and even asked Honda, and then stumbled upon that site. It's a must for 90-93 Accord owners.
Old 09-04-2004, 02:40 PM
mgcatthew mgcatthew is offline
Send a message via AIM to mgcatthew Send a message via Yahoo to mgcatthew
reading this post took me back to when i had my problems with the relay
scooby-dooby doo!!!!!
