Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-01-2004, 04:25 PM
imcoolerthenuha imcoolerthenuha is offline
Send a message via AIM to imcoolerthenuha
Got some questions, someone help?
I have a 1986 caprice with a 4.3 liter V6 and i was wondering, with all the smog junk on there how hard is it to change the plugs? and also is it hard to tear down because my valve seals are leaking down and the car puffs some smoke here and there, also its got a metric tranny in it will a 350 turbo drop right in? because i have one in my garage and i would love to install in my car just curious if it can be done with some sort of ease, I hope someone out there can answer these questions.
Josh K
1986 Chevy Caprice
Old 09-05-2004, 12:43 AM
2octops 2octops is offline
Re: Got some questions, someone help?
Should be able to change the plugs and all fairly easily unless they are siezed. Valve stem seals should be able to be replaced in a few hours with right tools and mechanical ability. Just dont drive the new ones down to far or you will have same thing you have now. Not so sure about the tranny, size should fit, but not sure about what tranny mount to use and the linkage.
Old 09-05-2004, 12:57 AM
vetrus vetrus is offline
!!! PLS HELP!!!
i just bought a eagle talon tsi awd first gen, the lifters on the camshaft are making this clikicking noise, are they spungy lifters or what? is this bad what should i do, also i have a 16g turbo and i want 2 kno how 2 set the boost contoler and how not to go to high and everything some one pls help
Old 09-05-2004, 01:07 AM
Re: Re: Got some questions, someone help?
Originally Posted by vetrus
!!! PLS HELP!!!
You might want to consider asking over in the Eagle section of the forums.
Old 09-06-2004, 02:19 PM
misfit2004 misfit2004 is offline
Most tune ups are a pain.but worth it.at least you dont have one of those setups where some brilliant engineer put some or all of your plugs under the intake manifold!
As far as tranny goes,all GM turbohydras are interchangeable,but there are a few exceptions-the 350 and I belive the 700 overdrive trannies needed a support bar near the output end,where your driveshaft mounts to tran.You should have bolt holes pre drilled for this on your frame.The other issue I am aware of is that beginning in 1989 turbohydras were made with an electrical,computer controlled modulator instead of the vacuum modulator thats on yours.If the th350 you want to use is vacuum modulated and you have the bolt holes and the cross member,all should be well.
