Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-01-2004, 04:17 PM
jlharts jlharts is offline
Banned
Send a message via ICQ to jlharts Send a message via AIM to jlharts Send a message via MSN to jlharts Send a message via Yahoo to jlharts
secondary air injection/check engine
i'm somewhat knowledgable about what goes on under my hood but a check engine light with secondary air injection system poping up as a code is throwing me for a loop any help would be much apr. thanx! to any one who can help
Old 01-20-2005, 09:25 PM
Meindert Zwaagstra Meindert Zwaagstra is offline
Re: secondary air injection/check engine
You need to be more specific on the actual code (#) There are many parts that make up that system. First you need to locate the fuse for the pump and see if it is blown. If blown, it's the pump. If not, you need to disconnect the hose that leads to the exhaust manifold (near the pump itself/ with the engine COLD.) At cold start-up (when the pump is suppose to be working), see if the pump is blowing air. It suppose to run for a short time, probably no more than 4 minutes If not, there are a number of components that could be the problem. The vaccuum valve/ solenoid, the air pump/solenoid relay and air shutoff valve. If its blowing air, you might check the check valves near the block on each bank ( if your code specifies a left or right bank. Don't burn yourself on a hot engine and turn it off please!!! ) If your code does specify a particular bank (right or left ), try switching the check valves to see if the code switches to the other bank, provided you have a code scanner handy. GOOD LUCK
Old 04-17-2005, 09:39 PM
draxxus's Avatar
draxxus draxxus is offline
Send a message via MSN to draxxus
Yeah, do what he said... The same thing happened to me, i just changed the fuse and that fixed it for a short while, but the little clicking sound you hear came back. good luck. when you fix it, post back what you did, lol, i need to do it too.
drax
RHC Member #265
death smiles at each of us, the least i can do is smile back
1952 Willys M38A1 (Stout Mofo) (Dormant)
1995 Jeep Cherokee (Dead)
1996 GMC Sierra (Dead)
1998 Jeep Cherokee (Dead)
1998 Trans Am (Very Nice, Black, Leather, T-Tops, CD, LS1...)
Closed Thread
