Old 09-01-2004, 11:59 AM
AggieENGR AggieENGR is offline
What to do with my '93 4.3L Swap or not?
Hello Everyone, this is my first post here at Automotive Forums. Its great to be here.
I wanted to get some feedback on what I should do with my 1993 4.3L C1500 Cheyenne (114K miles). I've read a little about engine swapping and got really excited about the idea of throwing a big block in, but I know there are lots of hidden costs and potentially annoying issues that can arise. My question is, would it be worth it to upgrade this old 93 or should I look into buying a newer truck with a big block already in it? I just can't stand the lack of power and torque from my V6. I've got to get more displacement. Thank you for your feedback, have a great day
Jim
Old 09-01-2004, 03:28 PM
Ground Rat's Avatar
Ground Rat Ground Rat is offline
Send a message via AIM to Ground Rat
Re: What to do with my '93 4.3L Swap or not?
If you will be able to perform the swap yourself, I'd say go for it. Realize there will be a lot more involved than just an engine swap. The trans and rearend will have to be upgraded too, as well as suspension.
'87 Turbo Sprint
'90 Turbo Voyager
'92 Typhoon #591
Old 09-01-2004, 03:32 PM
broughy84's Avatar
broughy84 broughy84 is offline
he's right, if you go to a big block. Why don't you just go to a 350? All you have to do is change the computer and use the injectors off the 350. Not real hard....a big block would definately be harder than a 350....BTW did you know a 4.3L is a 350 with 2 cylinders whacked off of it?
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 09-01-2004, 03:54 PM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
Does the tranny mate to it?
Old 09-03-2004, 02:00 AM
Ok so if I went with the 350, would I need to upgrade the transmission also? From what I've read, if you want to do it right, there's a lot more involved than just swapping motors and computer chips. If I were to do this I would want it to be just as good as a factory 350. Could I achieve that easily through computer and engine swap? Thanks guys, I really appreciate the feedback.
Jim
Old 09-03-2004, 12:23 PM
broughy84's Avatar
You dont' need to swap trans. The 4.3 & 5.7 have the EXACT SAME bell housing bolts and they mate to the exact same trans, 700r4 or 4l60e. Just pull the motor. don't worry about your trans....i took a trans out of an astro van with the 4.3 in it and put it in my silverado.
Matthew Brough
Old 09-04-2004, 04:12 AM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
Thanx for starting this thread aggie, I've been curious as to what all it will take on my '98 when the motor finally gives. I once helped my buddy swap his 4-banger to a 4.2L on his '95 S-10. It took a while to work out all the kinks but seems like going from a 4.3L to a 5.7L would a lot easier. A couple of things noone has spoke about yet that I'm curious of is the wiring harness(es)?!?!? And if the 4L60E mates, does that mean the gears in the rearend woulnd be ok also? I think mine will work because it's different than most factory 4.3's.
I would agree with GroundRat, if you are capable of doing this yourself (vs. mechanic shop(s)), go for it. I've been impressed with my 4.3L but of course I'm itchin' for more like you! And yes, the 4.3 is the exact same block as a 350 but minus the front 2, but still even has the same bore & stroke.
Good luck if you pursue it and it would be greatly appreciated if you kept me up to date!!
Old 09-07-2004, 11:06 PM
pcollins1 pcollins1 is offline
you could also trick out the 4.3 there are thousands of parts that fit it cams, computers, heads and so on,and then if you race it and win its always fun to say its just a 6 cylinder. ive seen several 4.3's that run better than a 350. but if you really want a bigger engine go for it its not hard if you have the correct wiring harness and computer. both ways are lots of fun. good luck
Old 10-08-2004, 10:10 AM
cdoogles cdoogles is offline
I'm about to swap my 1993 4.3L for a bored out 5.7L also. So, has anyone else tried this yet? It looks to me like the engine will be the simplest part. I'm slightly more concerned about the computers and wiring harnesses. It looks like you have to pull the dash to get the computer out, but Maybe you can get it out through the glove box, but Ihaent tried yet. Luckily I have the entire truck with the V8 sitting in my garage, just slightly totaled so I have all the parts neccessary. Good luck and any info would be appreciated. Thanks guys-
Old 10-08-2004, 11:40 AM
rpreston rpreston is offline
cdoogles, the ECM is behind the glove box. Easy to get to. I don't think you should have any concerns on the wiring harness. All the engine wiring is essentially the same.
[SIZE=3]"How do you feel about Women's rights?" " I like either side of them."[/size] - Groucho Marx
Old 10-10-2004, 04:18 PM
getusmonster getusmonster is offline
Send a message via AIM to getusmonster Send a message via MSN to getusmonster Send a message via Yahoo to getusmonster
4.3L swap
I was thinking of doing the same thing with my 95. But i have a 5 speed manual trans. The 5.7l will bolt directly to this tranny and all you have to do i s take off the glove box to swap computers. Wiring is easy just use holes already in firewall that current computer uses. Im hoping this is a very easy swap as i am doing it in Nacogdoches, Texas and there are not alot of mechanics here with any good things to say about them. I let you know what happens.
Old 10-10-2004, 04:19 PM
By the way this wouldnt happen to be slim jim would it? Used to go to A&M before was kicked for a couch burning!! Ha HA
