Old 09-01-2004, 11:48 AM
cav-fast cav-fast is offline
Send a message via AIM to cav-fast
computer output gone wrong
hey guys I need some help with my computer output on my 96, for some reason the dang thing will not put a read out to anything that is hooked up to it, I have gone over the wires in the back and can not find anything wrong with them, if you have any idias I would love to here from you.
Old 09-01-2004, 03:40 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: computer output gone wrong
are you using a scan tool or the old jumper wire trick??? 96-newer vehicles use an OBDII system that requires a scan tool to read. Take it to Auto Zone or Advance, they will scan it for free. If you are using a scan tool, some 95-early 96's have a interim design that requires a special adapter to read, due to a different pin configuration.
Old 09-01-2004, 03:58 PM
Question
I have tried it with the scan tool and it still came up with nothing, the tool shows me nothing at all. It is not the tool because I have used it on another car with no prob, any more tips?
Old 09-02-2004, 02:04 AM
'94CavyRs3.1 '94CavyRs3.1 is offline
Send a message via AIM to '94CavyRs3.1
not sure...but would a fuse for the ecu cause that? like a fuse bout to blow or not...? it may be a simple thing like that? or am i just dumb...its late..so i might be
"Live my life a 1/4 mile at a time" one of the best quotes..and something to live by.
MY CAVI ON CAR DOMAIN
Old 09-03-2004, 11:16 AM
I took it to my down home shop and they have looked to see if it was a fuse, I think that my next best thing is to take it into Chevrolet and tell them that they need to find were it is gone wrong. Thanks to everyone.
Old 09-03-2004, 02:08 PM
richtazz's Avatar
If you aren't even getting it to go into read mode, I believe you have a bad ECM. My 91 cav did the same thing, then started to intermittently cut the engine off. It will only get progressively worse
Old 09-03-2004, 07:56 PM
hey good point richtazz I never thought about that, I will give it a try, thanks
Old 09-04-2004, 06:47 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: computer output gone wrong
Don't EVER go to a dealership with that mind set.
You might as well give them a blank checkbook too.
They will piss around and hand you a $500 bill for nothing but the same car coming out of the shop.
