Go Back   Automotive Forums Car Chat > Mitsubishi > Mighty Max
Old 09-01-2004, 09:31 AM
nonamer66 nonamer66 is offline
Swapping the Instrument Cluster
I know this is a dead forum, but maybe someone can help me.
I'm wanting to replace my stock 115mph Instrument Cluster from my 95 Mighty Max with this 1990 MITSUBISHI ECLIPSE INSTRUMENT CLUSTER. I know going from 115 to 140 on the speedo and having a different size diameter of gauge will completely throw my speedometer readings off, but is it possible all I would have to do is swap the ECU from an Eclipse to my Mighty Max? You think it would be a smooth transition. Anyone have some knowledge they would like to share on this idea?
Old 09-04-2004, 12:52 PM
Delta Dart Delta Dart is offline
Re: Swapping the Instrument Cluster
Forget about swapping the ECU!!! This should be a mechanical cable operated speedo so recalibration will require some alteration of the drive gear to compensate for the different application.
Old 02-12-2005, 09:26 PM
dinoraver3466 dinoraver3466 is offline
an eclipse ecu swap will gain you hp and higher revs...
