Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-01-2004, 08:23 AM
Keith1998Isuzu Keith1998Isuzu is offline
Question Fuel pump relay clicking
This morning I went out to start my v6 r1998 rodeo and it would not start, I thought maybe I had killed it by leaving the lights on but this was not the case. I got the car jump started and started down the road. My ABS light and cel come on and the car kept stuttering, I pulled back up to my house and of course it will not start again. I tried to reset the computer by taking off the hot wire for 15 minutes and cleaning the terminals nothing. However when I turn the ignition key on my cel and abs both flash really quick continuously and there is a clicking from the fuel pump relay under the hood. I switched the realy after determing it was the same part as other ones and got the same result. Any ideas?
Old 09-01-2004, 08:38 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Fuel pump relay clicking
Your battery is bad. Isuzu don't like strange voltage.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 09-01-2004, 08:42 AM
Ok
I can buy that because it was dead this morning, however when I got it jump started and started down the street could the battery still be causing problems while running?
Old 09-01-2004, 08:56 AM
Unhappy Not car smart
I am going to go take the battery down to advanced auto to have them check it at lunch but the fact remains that I really dont know..... what uses the battery while the car is running? I might be an idiot but I thought that you only used the battery when you were starting the car or when the negine is off.
Old 09-01-2004, 11:58 AM
Well thanks for confirming my suspicions, yes it appears it was the battery causing all those faults. At least with the new battery they are gone at the moment. I am still confused a little by what the battery does after the genrator takes over though. Mainly because after it was jumped and I rode around the block if I hit over 3000 RPM botht he tachometer and the speedometer would drop to 0 and then go bak up once I left the 3000 area, and the ABS lite was continuosly on and the CEL would flash on every once in a while. I find this very wierd.
Old 09-01-2004, 01:14 PM
Ramblin Fever Ramblin Fever is offline
It's not what the battery does, per say, after the engine's started. It's just the mere fact that the truck can sense "something's" wrong with it's electrical voltage.
These trucks crave good strong voltage consistently, and are VERY picky about it!!
That's one thing I've for sure learned myself this summer, and they also hate refurbished alternators!!
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 09-01-2004, 09:19 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
well alrighty then
