Go Back   Automotive Forums Car Chat > Chrysler > General Discussion
Old 09-01-2004, 08:17 AM
Sfrid073 Sfrid073 is offline
95 Lebaron no reverse
95 lebaron 6 cyl. auto. won't go into reverse. any ideas???
Old 10-26-2004, 02:20 PM
rwood13 rwood13 is offline
Re: 95 Lebaron no reverse
drain the trans fluid, if pieces fall out when you drop the pan, or there are a large amount of metal shavings in the pan then it is time for a rebuild or conversion to manual, if none of the above the you have a stuck valve or servo, if that is the case refill with tarns fluid and trans flush may free it, may need to pull it out and clean it, not as hard as it sounds, get a book on automatics
forgot, before anything check the fluid level
Old 11-01-2004, 11:43 AM
and you have found what??
Old 12-06-2004, 05:53 AM
Off_Road's Avatar
Off_Road Off_Road is offline
Hey rwood13,
Doesn't that trans model have a low-reverse band? Great suggestion to check the fluid level first. I would certainly check that and the condition of the fluid first thing. If those two check out fine. Then what? Maybe pull the pan check and see if you might not have a band strut or two laying in the pan. Maybe even a snap ring from an internal servo assembly. Other then that, if nothing found. Guess I'd have to try cranking down on the band a touch. Making an adjustment. Now Sfrid073 never mentioned if they were having any kinds of problem with 3rd gear? If it's major internal failure, I have no doubt that will be next. Since those same set of clutches are applied both in reverse and third gear.
