| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
If you have an FMU, you dont need a FPR right? Or do you? Also what do the different ratios mean. I have seen that a lot of people with turbochargers have gone with the 12:1, but what does the ratio pertain to? And, which one would be best for a turbocharged application? Thanks
95' LS Integra 5spd DC Header (4-2-1) HKS Super Dragger Exhaust Skunk2 Short throw shifter Ground Control Coilovers Strut Bar -SOON to be putting in a JDM B16 hydraulic tranny with lightened flywheel and stage III clutch -SOON to be "home made" turbo charging (goal = 12psi) -GOAL = 250-300hp with stock internals(probably not reachable) |
Re: FMU's
i dont really remember i think for a a 12:1, every pound of boost is gonna raise fuel pressure by 12psi. cant say for sure. isnt the FMU a FPR so to say?
Re: Re: FMU's
Re: FMU's
If I'm correct 12:1 would be 12 parts fuel 1 part air...
and from my understanding the FPR and EMU are kinda the same w/ the exception w/ some of the FMU you can change the fuel part, 12:1 to 13 or 11:1...
another good honda site: www.civicland.com
if your gonna go turbo a good a/f would be around 12:1 or 12.5:1
if you wanna get a management of some kind i would recommend aem, hondata or eberdata. |
Re: FMU's
i disagree that the FMU controls a/f, because the FMU is connected only to the fuel line, it cant control the fuel injectors which are responsible for the volume of fuel that gets introduced into the intake manifold/ports.
Re: FMU's
heres the fuel article Cartech
Re: FMU's
12:1 IS to high for some applications, Expecially if you got Aftermarket Injectors. Picture This: You are running 10 PSI of Boost on the turbo, and you have a 12:1 FMU. The vacume line is atached to the Intake Manifold, thats how the FMU knows. You boost to 10 PSI. (12*10=120) so you have 120 PSI of fuel, not including the 40PSI that you have at 0 boost. so that is roughly 160 PSI of fuel!! Not many fuel pumps can handle that, yet alone any fuel systems. So many Turboers use HonData or an AFC to tune the ecu to do it automaticly. Most Turbo Dudes, will say Fuck the FMU. Just because they are included in some Turbo Kits, doesn't mean they are very good.
And NO, Fuel Regulators are not the same as Fuel Managment Units, but kinda, in the fact that they controlle fuel.
![]() ![]() Ya, It's Turboed. |
Re: Re: FMU's
Re: Re: Re: FMU's
Re: Re: Re: FMU's
And a 12:1 FMU is boost referenced and bumps your fuel pressure up 12 psi for every 1 psi of inlet pressure. |
technically the FMU is a FPR. why? fuel regulator regulates the fuel pressure allowed. the FMU is sort of a variable regulator ; it still regulates fuel but changes the pressure accordingly to a variable(boost). if you read the article, cartech calls it a rising rate fuel regulator instead of FMU. ive only seen i think two manufacturers that call it FMU, the only one i can remember right now is Vortech.
Re: Re: Re: Re: FMU's
Re: FMU's
Wow, This guy is smokin some great shit. 800cc. J/K.
That setup (4 psi) might be posibile on 400 cc. If you want to drive your car on the street, pretty much never go over 550 cc injectors.
