Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-31-2004, 08:26 PM
eddie8 eddie8 is offline
overheating
I have a 94 camry v-6 that only overheats at highway speeds. Does not heat up in town. I have changed w/p, rad./ t-stat. and cap. Does not use any water and no steam from exhaust. The fan works as it should with engine rpm's. HELP!
Old 09-01-2004, 08:56 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: overheating
"The fan works as it should with engine rpm's."
I don't understand this statement.
It is possible your bottom (suction) hose is collapsing under load. Also, your thermostat may not be opening up all the way. Did you buy a Toyota thermostat? If not, that may be the reason. Did you install the thermostat correctly? (just checking)
Old 09-01-2004, 11:27 AM
jmrev's Avatar
jmrev jmrev is offline
Re: overheating
do you drive with the AC on
