Old 08-31-2004, 07:40 PM
sLADe781 sLADe781 is offline
Flat tire???
I have my PSI levels like the factory recommendations and my 2 front tires look a little flat--like it could use some more air or something. Does anyone else here follow the factory recommendations and seem a bit flat? Should I add more air? If so, how much?
Old 08-31-2004, 08:56 PM
StealthModifier StealthModifier is offline
Re: Flat tire???
Im not sure what the factory recommendations are, but im pretty sure its 29 all around.. but i put 31 in the front and 29 in the back... but i have 19" rims with low profile tires
Old 08-31-2004, 11:16 PM
Re: Flat tire???
For my '94 SL, it's 32 PSI up front and 29 PSI in the back.
Old 09-01-2004, 01:14 PM
thre3kgt811 thre3kgt811 is offline
does anyone know if its better with front wheel drive to have more inflated tires for better traction or a little less? whats the best setup???
Old 09-01-2004, 07:44 PM
Igovert500's Avatar
blue + red light magnet
Re: Flat tire???
I run 35 up front and 32 in the back on my 96 vr4
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 09-01-2004, 09:34 PM
Re: Flat tire???
If you go by factory recommendations, doesn't the front tires look flat?
Old 09-01-2004, 09:54 PM
Re: Flat tire???
I thought the factory recommendations had it as the same number all the way around... so its gonna look lower in the front cuz its heavier there
Old 09-02-2004, 01:31 AM
Re: Flat tire???
Well, on the driver door side panel, there's a sticker/tag there that tells you the PSI levels for the tires. I don't know if it's the same for Stealths but for GTs then there should be one.
Old 09-02-2004, 03:05 PM
youngmanvr4 youngmanvr4 is offline
Re: Flat tire???
Go to http://www.stealth316.com/0-frames.htm then click specifications, then under drivetrain click wheels, then go down to the bottom of the page and it should give you in info you need for your model.
dsm97gsx is now youngmanvr4.
94 vr-4 with 58k.
Mods: K&N FIPK, HKS EVC IV, HKS boost gauge, testpipe, EGR by-passed.
Sound: Profile Chrome and Gold amplifier (200W) and (2) 10" Red Cone Sony Xplod Subs.
Coming soon: Stillen downpipe, DN rear pre-cat, Defi boost and EGT gauge's with control unit on A-pillar.
Old 09-02-2004, 05:41 PM
Re: Flat tire???
There is nothing on my drivers side that tells me the PSI
Old 09-02-2004, 06:14 PM
Igovert500's Avatar
Re: Flat tire???
Mine says 35 in the front and 32 in the back, due to the extra weight from the engine up front.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 09-02-2004, 08:53 PM
Re: Flat tire???
Yeah, Stealths probably don't have the sticker. I'm guessing that it should be about the same as a GT so for a '94 SL, it's 32 in the front and 29 in the back.
Old 09-02-2004, 10:29 PM
Re: Flat tire???
alright.. isnt the weight of the car there too? is the weight the GVRW?
Old 09-03-2004, 12:24 PM
Gvrw???????????
Old 09-03-2004, 12:52 PM
GritMaster GritMaster is offline
heheh
it's Actually GVWR and it stands for Gross Vehicle Weight Rating and I beleive it is the mximum weight of the car, Including full fuel and the passenger/cargo etc. Go over that weight and You probbly void any warranty on your chassis (if it's even still running)
RIP Andy "Hypsi87" Filson... We'll miss ya mate
Originally Posted by nissanstreetz
For about 700 dollars you can have about 80 horespower at the wheels and about 70 torque.
