Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 02-08-2002, 01:38 AM
AJP10 AJP10 is offline
T25 Manifold Question
I was told it was possible to take a T25 manifold and weld a T3 flange to it allowing me to use a T3/T4 turbo. In doing my research I found out the flange is only $23.00 so would it be worth taking my T25 manifold and converting it or is there a big difference between the F-Max and my idea?
Old 02-08-2002, 07:33 AM
P10DET's Avatar
P10DET P10DET is offline
Re: T25 Manifold Question
I think there are clearance issues with the block IIRC.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 02-08-2002, 07:48 AM
davide169 davide169 is offline
Send a message via ICQ to davide169 Send a message via AIM to davide169 Send a message via Yahoo to davide169
with the bluebird (t-25) manifold there is a clearance problem with the block with any turbo larger than a t25. You need the gtir manifold to clear the block for a t28,t3,t3/t4 turbo.
You need to shave the block down to use the bluebird manifold with anything larger than the t25.
You are much better off going twith the gtir manifold which will take the t28 and t25 turbo stock. It's flange can also be changed to use the larger turbos.
