Old 08-31-2004, 07:18 PM
Phoenix69 Phoenix69 is offline
Oil Pan Gasket?
Hey,
I've posted about an oil drip on my passenger side, i got my oil changed and the pan was covered in oil on the outside. I think that my oil pan gasket needs to be changed or something atleast. Anybody have any idea the cost/ amount of labor to do it? Can i do it myself? does the gasket need to be replaced or can i seal it? I am quite confused.
Old 08-31-2004, 07:46 PM
stlwagon stlwagon is offline
Re: Oil Pan Gasket?
Looking at a couple hundred (at GM) since the engine and/or tranny have to be moved to access the pan. Not much you can do short of replacing the gasket.
Old 08-31-2004, 07:56 PM
Re: Oil Pan Gasket?
just a couple hundred? ive heard prices at around 1400$?
Old 08-31-2004, 08:59 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Ill see if I cant find my paper work for the repair of mine or at least the hours since they also replaced the rear main seal at the same time....~Larry~
ClubGP Member 6530
Since 2001
Old 08-31-2004, 09:16 PM
Re: Oil Pan Gasket?
thanks, i pray its cheaper or something i can do myself
Old 08-31-2004, 09:31 PM
BIG-L's Avatar
Wife has the car and is out shopping,so I should have it for you latter on tonight.
The engine has to be lifted out enough to get the Gasket out,since it has a so called windage tray built into the gasket....ive heard its a pain in the ass.....GM also had a TB out on the gasket and oil pan since it has ribbs and needs lots of RTV once the new gasket is replaced for it to hold its seal longer then it did from the factory.You may check and see if the bolts are tight,just a thought....but I do know that we all seem to have that problem.......~Larry~
Old 09-01-2004, 08:46 AM
Re: Oil Pan Gasket?
For the rear main it could cost between $1000-$1400. If only the oil pan gasket, looking at $150-$250 depending on where you go.
Old 09-01-2004, 12:59 PM
BIG-L's Avatar
Just found the paper work and you are correct.....it shows 8.8 hrs for rear main seal and 2.0 hrs for oil pan gasket which was only 147.00 for labor on replacing the gasket and 35 bucks for the gasket and get this, 13 bucks for RTV ....my total was a little over $1,200.00,thank god for an extended warranty with zero deductible.........~Larry~
Old 09-01-2004, 02:43 PM
Re: Oil Pan Gasket?
My rear main and oil pan total was $1494.06 ($354 parts & $1140 labor). But that also included a new oil pan. Mine too was under warranty!
Old 09-01-2004, 03:56 PM
Re: Oil Pan Gasket?
Oh my god...
Old 09-01-2004, 03:58 PM
Re: Oil Pan Gasket?
so wait if just get the oil pan gasket and whatnot fixed it will cost me 200$? i dont believe my rear main is bad
Old 09-01-2004, 04:23 PM
Re: Oil Pan Gasket?
Should be around there unless they discover something else when they have everything off.
Old 09-02-2004, 03:12 PM
Re: Oil Pan Gasket?
is it almost a given that my rear main seal with fail?
Old 09-02-2004, 03:30 PM
Re: Oil Pan Gasket?
It is a known problem with these engines as they approach 60-70000 miles.
Old 09-02-2004, 03:54 PM
Re: Oil Pan Gasket?
hm my car has 48k and is a 97
