Old 08-31-2004, 06:53 PM
Hyla1967's Avatar
Hyla1967 Hyla1967 is offline
diagnostic codes 93 prak ave.
How do I pull the diagnostic codes off my 93 Park ave.?
Is a place online that will list what the codes are too?
Old 09-01-2004, 10:56 AM
yogi_123rd yogi_123rd is offline
Re: diagnostic codes 93 prak ave.
Most GM vehicles use the following procedure:
Look under the dash under the radio/ashtray. There will be a 3"" rectangular electrical connector with two wires going to it. One wire is black (a ground wire) and the other is white?? (diagnostic mode enable). To enable diagnostic mode, ground the white wire - put a paper clip or wire in the connector sockets where these two wires are.
Turn the ignition on.
Watch the "service engine soon" light, it is used to flash the codes out. Count the flashes for each digit, a pause seperates each digit. Each code is repeated three times in succession until the end of the list. The code list begins with a code 12 marker. The list will repeat after the last code.
To get the meaning of the codes, then do a web search using keywords "GM Computer codes".
Old 09-01-2004, 02:06 PM
rotaran's Avatar
rotaran rotaran is offline
Send a message via MSN to rotaran Send a message via Yahoo to rotaran Send a message via Skype™ to rotaran
@Hyla1967:
Take a look:
http://www.geocities.com/dann8785/se...nginesoon.html
Mike
1991 Buick Park Avenue
1995 Ford Fiesta
Waghaeusel/Germany
Old 09-02-2004, 12:58 PM
Hyla1967's Avatar
Talking
Thanks! That link will help alot.
You wouldn't happen to know where the throttle position sensor is on that car? (93 Park Ave.)
