Go Back   Automotive Forums Car Chat > Honda > Integra
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-31-2004, 06:47 PM
integra123 integra123 is offline
top speed problem
when i first got my car i got it to 110 stock and thought it had a governor but i guess not. now i have headers and cat back, and cold air, but i still cant get it past that. it stop acelerating at 5000 rpms in 5th. need some help
Old 08-31-2004, 07:50 PM
gismo0184 gismo0184 is offline
Re: top speed problem
there is a governor, you need to find your ecm and find a black and white wire, that should be the wire for the governor. you can splice in a switch or just cut the wire and clip the ends.
Old 09-01-2004, 01:37 PM
ok thanks but are you sure there is a governor?? i looked it up in the forum and everyone else said there isnt. and i tried it again last night and i got to 130 but then it stopped there.
Old 09-01-2004, 04:58 PM
tsugsr tsugsr is offline
No such thing as a Governor on our cars gismo, there is however something that effects every single car out there, wind resistance, that can easily keep you from going very fast, as well as what RPM your shifting in.
Old 09-01-2004, 08:09 PM
my bad about the governor. other than wind resistance and rpm's why can't integra123 get past 130 and i can't get past 100??
Old 09-01-2004, 08:47 PM
i dont know but i was at 6000 rpms in 5th and i couldnt get faster then that, tho i had to slow down a little cause i was getting off the express way.
Old 09-01-2004, 09:33 PM
92gsr200k 92gsr200k is offline
Which year and model Integra do you have? I have a stock '92 GS-R and this past July I did a little over a two mile stretch doing 120 on the expressway and it felt like it had a few more mph in her. If you're maxing out at 100 mph, with the mods you've done, then either you're driving against the wind during a huricane, or something is wrong.
Old 09-02-2004, 12:53 AM
i have a 96 ls. and i does seem like there is more mph left it just takes a long time. next time i go out ill have to see how far i go
Old 09-02-2004, 04:17 AM
95TegSE's Avatar
95TegSE 95TegSE is offline
LS Trannies have considerably longer gearing than the 92-93 GSR, so that could be the difference there.
From the foothills to the bay, it shall ring, as we sing,
It shall ring and float away; Hail, Stanford hail! Hail, Stanford hail!
Old 09-02-2004, 12:51 PM
Rating's Avatar
Rating Rating is offline
Send a message via AIM to Rating
I dont find a reason to go 130 mph down the expressway. Nothing special about it only death.
Now if you were to do 130 in a 1/4 then that might be something to talk about. Personally im glad you guys cant make it over 100 or 110. Dont mean to sound rude or anything, just speakin the truth.
Im not proud of my car because its fast, Im proud of it be cause I built it that way.
Old 09-02-2004, 01:47 PM
Doubletap Doubletap is offline
Send a message via AIM to Doubletap Send a message via Yahoo to Doubletap
One way to test if you are really hitting the governor, nexttime try it downhill. Once you hit the limit set by the govenor your fuel and spark will cut out and the car will coast down 5-10 mph before you get any power back. It will feel like you just fucked something up big time and then it will drive normally up to the limit again and the cycle repeats until you get in there and do some ecu work.
DoubleTap
Old 09-02-2004, 06:02 PM
DeleriouS's Avatar
DeleriouS DeleriouS is offline
Send a message via AIM to DeleriouS
i have heard that, but i have never seen it. if you ask me i think that would be hazardous. (not that going 130 isnt). If you personally ask me i think it could be 1 of two things. it could be your horsepower. there is a word that comes into my mind. terminal velocity. just take that word and think about what it means. maybe thats the top engine horspower and speed that it can go against withought having to deal with wind resistance. another is a govener. they dont want your dumbass to go past a certain mph because your tires will go out. If you ask me, i love going about 130mph...its fun. But your tires cant stand that so they will blow out. that is why they have different ratings for tires. I think that our tires on the integra are H's (meaning cant go past 130mph). But my friend has a saab 900se turbo, and we were going 145 and still going - his speedometer ends at like 155mph too. i didnt check wat tires he has on his car. but with a turbo, your hp doesnt really have a "terminal velocity", thats what i think - it is possible that it does, but not until you get to the higher mph. another reason is wind resistance. you might not think so, but it has to do A LOT with your speed. also your drag coeficient(aerodynamics). and your transmission gears. it has to do with a TON of things. with my car i have only been able to get to around 125mph. then it just doesnt go any farther. but i did a calculation - if i got rid of my govener (if that was the case) i would be able to do around 158mph at 7000rpm's. sounds like fun. thats my hope you got a little better understanding of what i meant. not all of you will journey through my long and boring passage. lol
95' LS Integra
5spd
DC Header (4-2-1)
HKS Super Dragger Exhaust
Skunk2 Short throw shifter
Ground Control Coilovers
Strut Bar
-SOON to be putting in a JDM B16 hydraulic tranny with lightened flywheel and stage III clutch
-SOON to be "home made" turbo charging (goal = 12psi)
-GOAL = 250-300hp with stock internals(probably not reachable)
Old 09-02-2004, 07:20 PM
now people are saying there's a governor. what's the truth, is there or not? might just have to go looking my self.
Old 09-02-2004, 11:22 PM
ya thats what i want o know. some people say there is and some say there isnt. But i havent had any more troble getting past 110 tho, so i guess not.
Old 09-03-2004, 11:00 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
To my understanding all cars have govenor.
Closed Thread
