climate control
fan, blower motors all work but can't adjust temperature for ac or heat has the digital readout for temp control. the readout works but the temp doesn't change at all from hot to cold or visa versa
Re: climate control
does it say "ER" on the display when you first turn it on?It sounds like a bad blend door actuator.
Re: climate control
. then i thought about getting a new one (~$60 or so) and thought hmmmm i'll take it apart and see. i noticed the gears wouldnt turn inside... they were locked. i slid one out..... now they turned, so i knew it was just the one gear. Did some playing around with it and got it to turn again. tested a hooked and it worked fine. now its all back together and running perfectly. of course.....THIS after i replaced teh thermostat, replaced all teh coolant, flushed the rad and heater core.... wouldnt you know it.
Re: climate control
This is just the info I am looking for! Thanks!
Re: climate control
I also found that my floorboard under the passenger seat carpet is wet, and I saw some posts in here anout that, so I will go back and find out how to resolve that one! As an aside, I drove my Wife's 99 JGC and it now won't blow warm! That one has a warranty, so we shall see what happens. Great Forum, With a 99 JGC Laredo, and a 97 JGC Limited, I am certain to be a regular! |
Re: climate control
Here's a link to the wet floorboard problem and fix: http://home.sc.rr.com/janet/TSB/24-06-96.htm
1984 AMC Wagoneer Limited (RIP - Burned) 1996 Chrysler Grand Cherokee Limited (for sale) 1999 Chrysler Sebring Convertible JXi 2004 BMW X3 |
