Old 08-31-2004, 07:18 PM
HONDACIVICSI1990 HONDACIVICSI1990 is offline
Send a message via AIM to HONDACIVICSI1990
need help badly
okj i got white face gauges by trading tha ones for my integra
so i tried puting them in and they were kinda samll on tha temp/gas one and slightly small one tha rpm's so i just took them off
ok now heres my question i did not take off tha needles but my rpm one is near zero at idle but i think it is fine when drvign whaT HAPPENED?
1990 honda civic si
-Im Spanish
Bad Boys Racing Development
Old 08-31-2004, 07:43 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: need help badly
Okay, first off did you get a pair of 90-91 gauge faces. Cause the 88-89 will not work. The gauges are just a little bigger I beileve. I'm compared them one time. Also, they should be meant for the civic cause if they're for the CRX, the gauges on them are held into place differently. I tryed this on my crx gauge in my civic.
And for the idle being off near zero. There is two possiblitys, either u touched the tach needle somehow (they are very, extremely sensitive) or your idle is very low. Try adjusting your idle to see if it jumps up.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 08-31-2004, 07:59 PM
Re: need help badly
no my idle is fine
it should be at 550 liek it was before i pulled tha cluster out and tryed tha gauges
1990 honda civic si
-Im Spanish
Old 08-31-2004, 11:09 PM
Re: need help badly
i still need help on my rpm problem
1990 honda civic si
-Im Spanish
Old 09-01-2004, 02:58 PM
Shaguar47's Avatar
Re: need help badly
Dude, you have to wait on replys, people aren't just going to send you a message every 5 minutes.
Okay, it seems like your idle is fine. So look at the other thing I posted. The only thing I can think of is that you touched the needle (somehow) when installing those white gauges and it screwed it up. It also could be that one of the plugs behind the gauge that plugs into it might be loose. I could also be that maybe the white gauge covers are maybe rubbing up against the needle letting it not move all that easy. See if those are the problems. If not, you might have to look for another gauge cluster.
