Old 08-31-2004, 06:10 PM
jumpingjack66's Avatar
jumpingjack66 jumpingjack66 is offline
Send a message via Yahoo to jumpingjack66
lubricating accelerator pedal 2000 silv
Can sombody tell me how to lub this accelerator pedal? i asked my dealer to do it and it was missed. Pedal is stickyperticularly at idle position. also what type of lub is required? Thanks....JJ
Old 08-31-2004, 08:31 PM
pedal update
Ok after going further back in the threads i find that this is probably a throttle body prob. specifically do i take the t/b off to clean and adjust that screw on the bottom or can this all be done on the engine? Thanks...JJ
Old 09-01-2004, 09:00 AM
Seabornman Seabornman is offline
There is a TSB that explains official chevy way to correct. I was able to correct the problem on my '01 by removing the rubber intake "hose" and liberally applying carb cleaner to the interior of the throttle body, especially where a carbon buildup can be seen, and doing the same to the exterior linkage and spring at the shaft. Has been good for two years. May need to be done again.
Old 09-01-2004, 05:37 PM
rustcal rustcal is offline
Send a message via AIM to rustcal Send a message via Yahoo to rustcal
make sure you use throttle body cleaner and not carb cleaner. a few mechanics said that carb cleaner is to hard on throttle bodies.
Old 09-01-2004, 07:05 PM
tidalcock tidalcock is offline
Re: lubricating accelerator pedal 2000 silv
The Haynes manual warns not to use any cleaner that contains Methyl Ethyl Ketone (MEK), as it could damage the trottle body.
Old 09-01-2004, 08:08 PM
ok thanks guys...JJ
